Have you put it together yet? I started putting our kit together today, and a lot of the holes don’t seem to line up very well. I was wondering if this was a wide spread issue.
All holes lined up - the key is to use the rubber feet (height alignment with the fence bracket holes) and base plate locations (which side of the tiles the standoffs are located seemingly matters).
I had to have people push on both sides of the field to get the fence holes lined up. Also, some weren’t drilled in the center, they were off a bit. which, when added up, caused the problem.
Maybe better put this way: VEX is billed $1000 by a transport company and they pass this onto you.
International freight isn’t cheap unless it’s by sea and that is totally impractical for a few boxes.
Eagle-sharp eyes!
Sigh… Now our secret is out… Think my students will slaughter me for info leakage
It is marine plywood. And it serves 2 purposes - the lab used to flood from water leaking from the ceiling.
And the field used to be resting on tables. But we moved it down since nbn season. But the plywood does made shifting of field much easier and allow us to do levelling of the field easier too.
