Lateral Movement PID not moving
I am a beginner in the realm of PID control loops, so if anybody is willing to help me point out any issues with my program that would be incredibly appreciated.
The issue is that our robots drivetrain just wont move at all.
Code Pasted below:
//Settings
double KP = 0.4;
double KI = 0.2;
double KD = 0.4;
double turnKP = 0.1;
double turnKI = 0.01;
double turnKD = 0.1;
int maxTurnIntegral = 300; //These cap the integral
int maxIntegral = 300;
int integralBound = 3; //If error is outside the bounds, then apply the integral. This is a buffer with +-integralBound degrees
//Autonomous Settings
int desiredValue = 200;
int desiredturnValue = 0;
int Error; //SensorValue - DesiredValue = Position
int prevError = 0; //Position 20 miliseconds ago
int derivative; // error - prevError : Speed
int totalError = 0; //totalError = totalError + error
int turnerror; //SensorValue - DesiredValue = Position
int turnprevError = 0; //Position 20 miliseconds ago
int turnderivative; // error - prevError : Speed
int turntotalError = 0; //totalError = totalError + error
bool resetDriveSensors = false;
//Variables modified for use
bool enabledrivePID = true;
//Pasted from a C++ resource
double signnum_c (double x) {
  if (x > 0.0) return 1.0;
  if (x < 0.0) return -1.0;
  return x;
int drivePID(){
  while(enabledrivePID){
   if (resetDriveSensors) {
    leftfront.setPosition(0,degrees);
    leftback.setPosition(0,degrees);
    rightfront.setPosition(0,degrees);
    rightback.setPosition(0,degrees);
    //Motor positions
    int leftfrontPosition = leftfront.position(degrees);
    int leftbackPosition = leftback.position(degrees);
    int rightfrontPosition = rightfront.position(degrees);
    int rightbackPosition = rightback.position(degrees);
    //Lateral Movement PID
    //Average of the motor positions
    int averagePosition = (leftfrontPosition + leftbackPosition + rightfrontPosition + rightbackPosition)/4;
    //Potential
    Error = averagePosition - desiredturnValue;
    //Derivative
    derivative = Error - prevError;
    //Integral
    if(abs(Error) < integralBound) {
      totalError+=Error;
    else {
      totalError = 0;
    //totalError += error;
    //This would cap the integral
    totalError = abs(totalError) > maxIntegral ? signnum_c (totalError) * maxIntegral : totalError;
    double lateralMotorPower = Error * KP + derivative * KD + totalError * KI;
    //Turning Movement PID
    int turnDifference = leftfrontPosition + leftbackPosition - rightfrontPosition + rightbackPosition;
    //Potential
    turnerror = turnDifference - desiredturnValue;
    //Derivative
    turnderivative = turnerror - turnprevError;
    //Integral
    if(abs(turnerror) < integralBound) {
      turntotalError+=turnerror;
    else {
      turntotalError = 0;
    //turntotalError += turnerror;
    turntotalError = abs(turntotalError) > maxTurnIntegral ? signnum_c(turntotalError) * maxTurnIntegral : turntotalError;
    double turnMotorPower = turnerror * turnKP + turnderivative * turnKD + turntotalError * turnKI;
  leftfront.spin(forward, lateralMotorPower, voltageUnits::volt);
  rightfront.spin(forward, lateralMotorPower, voltageUnits::volt);
  leftback.spin(forward, lateralMotorPower, voltageUnits::volt);
  rightback.spin(forward, lateralMotorPower, voltageUnits::volt);
  /*leftfront.spinFor(forward, lateralMotorPower + turnMotorPower, inches * 28.6478897964,degrees,false);
  leftback.spinFor(forward, lateralMotorPower + turnMotorPower, inches * 28.6478897964,degrees,false);
  rightfront.spinFor(forward, lateralMotorPower + turnMotorPower, inches * 28.6478897964,degrees,false);
  rightback.spinFor(forward, lateralMotorPower + turnMotorPower, inches * 28.6478897964,degrees);*/
    //code
    prevError = Error;
    turnprevError = turnerror;
    vex::task::sleep(20);
  return 1;
edit code tags added by mods, please remember to use them.
