teeope
October 22, 2016, 8:19am
#1
For the competition StarStruck, my and my teams launch is a gear system with touchsensors to lift the launch, and then another touchsensor to lower it. We also have a high hang, which is programmed to 2 buttons to lift and lower. Could you tell me if my program will work the way i want it to?
#pragma config(Sensor, dgtl1, touchsensor1, sensorTouch)
#pragma config(Sensor, dgtl2, touchsensor2, sensorTouch)
#pragma config(Motor, port2, wheel1, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port3, lift, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port4, wheel2, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port5, lift, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port6, launch1, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port7, launch2, tmotorVex393_MC29, openLoop)
//*!!Code automatically generated by 'ROBOTC' configuration wizard !!*//
task main()
while(1==1)
if(SensorValue(touchsensor1) == 1 )
motor[port6] = 127;
motor[port7] = 127;
if(SensorValue(touchsensor2) == 1 )
motor[port6] = -127;
motor[port7] = -127;
motor[port2] = vexRT[Ch3];
motor[port4] = vexRT[Ch2];
if(vexRT[Btn6U] ==1)
motor[port5] = 127;
motor[port3] = 127;
if(vexRT[Btn6D] ==1)
motor[port3] = -127;
motor[port5] = -127;
else
motor[port3] = 0;
motor[port5] = 0;
I reformatted you code to make it a little easier to read, it’s probably not going to work the way you want it to at the moment, I will move this thread into the general forum so the community can comment and, hopefully, give you some help.
Connor
October 22, 2016, 9:47pm
#3
teeope:
task main()
while(1==1)
motor[port6] = 127;
motor[port7] = 127;
motor[port5] = 127;
motor[port3] = 127;
else
motor[port3] = 0;
motor[port5] = 0;
One thing I noticed is that you don’t contain an “else if” statement after the first “if”. Another is that you should use brackets to describe motors AND sensors. (Example “SensorValue[touchsensor2]”)
Here’s a your code tweaked:
task main()
while(1==1)
if(SensorValue[touchsensor1] == 1 )
motor[port6] = 127;
motor[port7] = 127;
if(SensorValue[touchsensor2] == 1 )
else if(vexRT[Btn6U] ==1)
motor[port5] = 127;
motor[port3] = 127;
else if(vexRT[Btn6D] ==1)
else
motor[port3] = 0;
motor[port5] = 0;
Note: I may need more information and probably some pictures to allow me to be able to see if there’s anymore changes. I also noticed a strange ‘fighting’ or a clash of two similar things set at different values, is it fine if I try to remake the code?
Connor
October 22, 2016, 9:56pm
#4
I messed with some curly-bracket placing, and I messed with the logic statements:
task main()
while(1==1)
motor[port6] = 127;
motor[port7] = 127;
else if(SensorValue[touchsensor2] == 1 )
motor[port5] = 127;
motor[port3] = 127;
else
motor[port3] = 0;
motor[port5] = 0;
Note: It seems that there isn’t a button to control the catapult and lift, is there supposed to be one?
