LCD code chooser help
Hello, 8686K here, I have been having trouble with the LCD display recently, I have made a code chooser program for my robot last year but when I try to make one this year it doesn’t seem to work. If anyone can take the time to look at it I’d appreciate it.
	#pragma config(Sensor, in1,    gyroscopicSensor, sensorGyro)
	#pragma config(Motor,  port2,           ldwMotor,      tmotorVex393_MC29, openLoop, reversed)
	#pragma config(Motor,  port3,           rdwMotor,      tmotorVex393_MC29, openLoop)
	#pragma config(Motor,  port5,           lfwMotor,      tmotorServoContinuousRotation, openLoop)
	#pragma config(Motor,  port6,           rfwMotor,      tmotorServoContinuousRotation, openLoop)
	#pragma config(Motor,  port8,           intakeMotor,   tmotorVex393_MC29, openLoop)
	#pragma platform(VEX)
	#pragma autonomousDuration(20)
	#pragma userControlDuration(120)
	#include "Vex_Competition_Includes.c"   //Main competition background code...do not modify!
void pre_auton()
task autonomous()
AutonomousCodePlaceholderForTesting();
task usercontrol()
	while (true)
    motor[ldwMotor] = vexRT[Ch3] / 2;
    motor[rdwMotor] = vexRT[Ch2] / 2;
if(vexRT[Btn6U] == 1)
    motor[lfwMotor] = 127;
    motor[rfwMotor] = -127;
else if(vexRT[Btn6D] == 1)
    motor[lfwMotor] = 0;
    motor[rfwMotor] = 0;
else
//Intake Control
if(vexRT[Btn5U] == 1)
    motor[intakeMotor] = 127;
else if(vexRT[Btn5D] == 1)
    motor[intakeMotor] = -127;
    else
    motor[intakeMotor] = 0;
UserControlCodePlaceholderForTesting();
im sorry it doesn’t have the lcd stuff, the other one had too many errors to even fix
Not sure how we’re supposed to look at your LCD selection code if it’s not there? Can you post the previous code even if it had errors?
void pre_auton()
	const short leftButton = 1;
const short centerButton = 2;
const short rightButton = 4;
//Wait for Press--------------------------------------------------
void waitForPress()
	while(nLCDButtons == 0){}
	wait1Msec(5);
//Wait for Release------------------------------------------------
void waitForRelease()
	while(nLCDButtons != 0){}
	wait1Msec(5);
	//Declare count variable to keep track of our choice
	int count = 0;
	//------------- Beginning of User Interface Code ---------------
	//Clear LCD
	clearLCDLine(0);
	clearLCDLine(1);
	//Loop while center button is not pressed
	while(nLCDButtons != centerButton)
		//Switch case that allows the user to choose from 4 different options
		switch(count){
		case 0:
			//Display first choice
			displayLCDCenteredString(0, "Autonomous 1");
			displayLCDCenteredString(1, "<		 Enter		>");
			waitForPress();
			//Increment or decrement "count" based on button press
			if(nLCDButtons == leftButton)
				waitForRelease();
				count = 3;
			else if(nLCDButtons == rightButton)
				waitForRelease();
				count++;
			break;
		case 1:
			//Display second choice
			displayLCDCenteredString(0, "Autonomous 2");
			waitForPress();
				waitForRelease();
				count--;
				waitForRelease();
				count++;
			break;
		case 2:
			//Display third choice
			displayLCDCenteredString(0, "Autonomous 3");
			waitForPress();
				waitForRelease();
				count--;
				waitForRelease();
				count++;
			break;
		case 3:
			//Display fourth choice
			displayLCDCenteredString(0, "Autonomous 4");
			waitForPress();
				waitForRelease();
				count--;
				waitForRelease();
				count = 0;
			break;
		default:
			count = 0;
			break;
task autonomous()
	//Clear LCD
	clearLCDLine(0);
	clearLCDLine(1);
	//Switch Case that actually runs the user choice
	switch(count){
	case 0:
		//If count = 0, run the code correspoinding with choice 1
		displayLCDCenteredString(1, "is running!");
		wait1Msec(2000);						// Robot waits for 2000 milliseconds
		// Move forward at full power for 3 seconds
		motor[rightMotor] = 127;			// Motor on port2 is run at full (127) power forward
		motor[leftMotor]	= 127;			// Motor on port3 is run at full (127) power forward
		wait1Msec(3000);							// Robot runs previous code for 3000 milliseconds before moving on
		break;
	case 1:
		//If count = 1, run the code correspoinding with choice 2
		// Move reverse at full power for 3 seconds
		motor[rightMotor] = -127;			// Motor on port2 is run at full (-127) power reverse
		motor[leftMotor]	= -127;			// Motor on port3 is run at full (-127) power reverse
		break;
	case 2:
		//If count = 2, run the code correspoinding with choice 3
		//Turn right for 3 seconds
		motor[rightMotor] = -63;			// Motor on port2 is run at half power reverse
		motor[leftMotor]	= 63;				// Motor on port3 is run at half power forward
		break;
	case 3:
		//If count = 3, run the code correspoinding with choice 4
		//Turn left for 3 seconds
		motor[rightMotor] = 63;				// Motor on port2 is run at half power forward
		motor[leftMotor]	= -63;			// Motor on port3 is run at half power reverse
		break;
	default:
		displayLCDCenteredString(0, "No valid choice");
		displayLCDCenteredString(1, "was made!");
		break;
	//------------- End of Robot Movement Code -----------------------
task usercontrol()
	while (true)
else
//Intake Control
    else
Alright, I fixed the task main but now it says there’s a duplicate definition and the count is not defined
Scratch the switch, just have a duplicate definition for task main now.
Ok ill try that
yep that seems to do it, thanks :slight_smile:
