Hello all, I am ITzzIKEI. I am programmer of team 950. Currently, we have a LCD Display hooked up to the back. We use it to tell our battery level. I am wondering what do you guys use it for. Thanks in advanced, as always have a nice day.
I actually started programming my LCD screen today aswell, and what I’ve gotten done today was display the battery voltage on the bottom line, and then have the top line display a menu where I can choose different autonomous routines using the buttons on the LCD screen or alternatively on the controller (when you get too lazy to bend down and press the buttons ).
I’ve also used it to show alerts/notices during autonomous, so if something goes wrong, it’s easier to debug when/where there’s a problem. For instance, I can use it when I have a PID controller timeout, and I can show some information about why it timed out, and debug from there.
Hope that helps!
Well it gave me an idea, I will try to make an if statement to output an error message if a motor gets unplugged.
Anyone got a good method for displaying voltages from the batteries on the LCD using EasyC?
I can find plenty of code for RobotC but since easyC doesn’t support strings I’m at a bit of a loss as to how to do it.
Right now it’s displaying a float value that’s huge, need to get it down to two decimals.
Thanks!
You can show battery voltage on easyC by using GetMainBattery(); block function and reporting that to a floating type variable (float). Then use DisplayLCDScreen(); block to choose the battery variable (float) in the variable selection box. Set the directive to %f (change %d (I think it’s d) to %f). You can add text before the %f by typing in the text box.
EasyC does support strings, the “string” type in ROBOTC is not a part of the C stdio library and is a ROBOTC extension. A string is just an array of char, most of the time you would do something like this.
// define a char array to hold a "string"
char str[32];
// use the "string"
sprintf(str, "Hello World" );
If you want to use your LCD display to select an autonomous program using easyC, you can find sample code here:
http://cybertotem.com/Blog/programming-the-vex-lcd-display-141
Is there a way to tell using RobotC if a motor is unplugged? It makes sense but I’ve never heard of being able to do that.
You just responded to a 2 year old thread.
