LCD Display
Hello all!
I have recently acquired an LCD display an my team has been messing around with it. We are trying to display the Primary battery level and whether a boolean is true of false. I had a quick question as a programming novice, what did we do wrong? All it shows on the lcd display is:
Battery:
Fly:  7cccc
Here is out LCD display code:
void battAndFlyLCD() {
	bLCDBacklight = true;
	clearLCDLine(0);  //clear line 1 (0) on the LCD
	clearLCDLine(1);	//clear line 2 (1) on the LCD
	string mainBattery;
	string flywheelStable;
	displayLCDString(0, 0, "Battery: ");
	displayLCDString(1, 0, "Fly: ");
	sprintf(mainBattery, "%1.2f%c", nImmediateBatteryLevel/1000.0,'V'); //Build the value to be displayed
	if (checkStable() == true) {
		sprintf(flywheelStable, "cccc", "READY");
	if (checkStable() == false) {
		sprintf(flywheelStable, "cccc", "NOT READY");
	displayNextLCDString(mainBattery);
	displayLCDString(1, 6, flywheelStable);
Any and all help would be fantastic. Please don’t be shy from telling us what we did wrong, we can get all the help we can get. Thanks!
P.S.- this is my first post on the vex forum :smiley:
Welcome
The code is pretty close, the main issue is trying to display “READY” and “NOT READY”. The statement
Will copy the string “cccc” to flywheelStable, what you wanted to do is give a format sting that would use the string parameter (READY or NOT READY) to be copied. You use the “%s” to specify this.
sprintf(flywheelStable, "%s", "READY");
There’s also a problem using displayNextLCDString, that will print on the second line as that was the last place you had accessed, some revised code below.
	string mainBattery;
		sprintf(flywheelStable, "%s", "NOT READY");
	displayLCDString(0, 9, mainBattery);
	displayLCDString(1, 9, flywheelStable);
Thank you so much. I assumed it would take a few days for anyone to reply, but in under an hour, the VP Technology of Robomatter replied! I will definitely start using the vex forums more often.
