can anyone give me a sample program for an LED. i want to use a potentiameter and have the LED light up at a certain value. i cant really make sense of the samples RobotC gives so. will sombody please help me
to my knowledge the led’s are strictly on and off. No brightness adjustment. But I may be wrong on that.
They are either on or off. But if you toggle it on and off really fast, then MAYBE it will look half bright. (That is basically how a motor runs half speed; it is called pwm. Someone with better circuitry knowledge?)
The motor ports have pwm with a motor controller. So if you plugged it into a motor port, you could just give it 64 power. Not suggested! (Unless you know what you’re doing, or you’re ok with frying electronics. :p)
to clarrify “light up” useally means turn on
Is this what you want?
#pragma config(Sensor, in1, pot_1, sensorPotentiometer)
#pragma config(Sensor, dgtl1, led_1, sensorLEDtoVCC)
//*!!Code automatically generated by 'ROBOTC' configuration wizard !!*//
task main()
while(1)
// Turn led off if pot is below 1000 or
// on if it is above or equal to 1000
if( SensorValue pot_1 ] < 1000 )
SensorValue led_1 ] = 0;
else
SensorValue led_1 ] = 1;
wait1Msec(10);
yes thanks
Misunderstood this, sorry.
