Hi I was wanting to use under glow on my bot this year Anyone have a program I could borrow to use my led lights pls help thanks
Or is there an easier way to use RGB strips without programming it would be a time saver
Take a look here:
I forget specifically if this is vrc legal because ot uses cortex electronics, but you probably can get away with it.
Or you can just attach your strips to an external power source, but you won’t have any control over it from the brain.
What type of external power supply could I use and of I use an external power supply will I still be able to use the light in a match ? Is that possible?
Review R12e and R18a in the Game Manual for the rules regarding power supplies for nonfunctional decorations.
