LED wire
i want to make the LED a certain distance from the cortex butdont know how. what kind of wire do you use ro connect the LED to the cortex. th LED has 2 wire prongs but the cortex uses 3 wire. im preety sure its not the motor controller although that makes sense since it goes from 2 to 3 wires.
You can use a regular 3 wire cable. Just MAKE SURE the keying is correct, don’t accidently flip the wiring like you can do with motors.
what do you mean by fliping the wirering
[ATTACH]7802[/ATTACH]
-10 char:)
oh ok makes sense
