Legal use of Y-Cables?
Is it legal to use Y-Cables in the Digital I/O ports and if so, is it legal to daisy chain Y-Cables?
I believe you can use them in sensor ports. I know you cant use them on motors or y-cable a y-cable
I see no rule against it, the only reference to Y cables is R12.
What are you trying to do ?
I suppose it makes sense to do this for button sensors as a system of physical OR gates if you’ve run out of sensor ports.
You are allowed to use Y-splits on everything, including motors. You can not Y-split a Y-split however. While designing Wallie V1, 4886c, we had to use Y splits since I was using a PIC brain
The manual never says anything about double Y-ing a sensor port; it only ever discusses motor ports.
I am trying to make multiple OR gates with buttons.
Interesting, I’ve always wondered about Y-cabling sensors. I don’t know if it will work. But I like the idea. :slight_smile:
Also, I wonder what would happen if the sensors being Y-cabled were different. Like say a Gyro and Potentiometer hooked up together.
Y-cabling works for boolean sensors as an OR gate: the output is 1 if either inputs are 1, and 0 if both inputs are 0. I suppose you could use it to average analog sensors, but you would have to non linearly map the output (Ohms law). Using y cables to combine other digital sensors, or different sensors altogether will give you no meaningful data.
I see. Thanks for the info :slight_smile:
Y of two potentiometers would likely provide an average of the two,
since there are no active circuits.
A Gyro has an active output buffer, so it would likely fight another active output.
Almost right. Y cable on bumper switches will be an active-low logic wired-OR.
Default input value is 1, provided by an internal (to the Cortex) pullup resistor.
Pressing A OR B switch (which shorts signal line to Ground) will cause input to read 0 instead.
This type of wired-OR active low is common in electronic circuits.
For example, several daughter-cards on a mother-board can share an interrupt line with wired-OR, so any one of them can signal “hey, there is a problem”.
The MB doesn’t know who yanked its chain, so it has to go ask each board individually (polling).
Wouldn’t a Y of two potentiometers basically put the two pots in parallel, causing you to receive a value that is related to (R1xR2)/(R1+R2) ? I guess it wouldn’t be the same as (potValue1 x potValue2)/(potValue1 + potValue2) though, so might not be very useful anyway.
You would have to be careful with putting two pots on a Y cable. If they are turned to opposite extremes you could have significant power flowing through them (in the neighborhood of 5W) which could damage them.
Cheers,
  • Dean
Yes, I am familiar with how the digital inputs work, I was referring to how they appear on a programming platform. ROBOTC at least registers 1 when the button is pressed and 0 when it isn’t (if the senosr configured as a button, which the OP said he was using). I’m don’t know if EasyC does this as well.
To make a log pot a fixed resistor is often put between the wiper and ground, this is the graph obtained using one pot midway and moving the other, a nice non linear curve.
[ATTACH]5857[/ATTACH]
As quazar said, it’s generally a bad idea as you can short power and ground with the pots at opposite ends. So the general rule here is don’t do it.
