Lift Drive Motors
Hey, some of my students have come up with a great lift model that they want to build. Only thing is i can’t seem to program 4 motors to one button. I can make motor groups of just two. Any sugestions?
Which programming software are you using?
Could you specify the programming language, or maybye show what you’ve coded so far?
Robotics V5 and i have the pro addition as well.
If you’re using vexcode v5 with blocks or text, you should be able to just set an if command. So set it to if the button is pressed, then spin these 4 motors. I don’t remember the exact code off of the top of my head but go check example code.
Great Idea, I will try that.
This worked perfectly. Thanks
I’m glad to be able to help!
