#include "vex.h"
using namespace vex;
competition Competition;
//remeber to set Rotation to 0 before actually turning anything
int x = 0;
int osc = 0;
int tod = 1;
int skil =1;
int hang = 2;
int oscState = 0; // 0: Not oscillating, 1: Oscillating
bool liftPIDRunning = false;
double target = 278;
int direction = -1;
int liftpid(){
liftPIDRunning = true;
Lift.setStopping(hold);
double kp = 0.018; // Proportional gain (adjust as needed)
double ki = 0.003; // Integral gain (adjust as needed)
double kd = 0.02; // Derivative gain (if needed)
double min_speed = 100; // Minimum speed to maintain movement
double max_speed = 100; // Maximum speed limit
double current = Rotation8.position(deg); // Current position
Rotation8.resetPosition(); // Reset encoder position
double integral = 0.0; // Initialize integral term
double previous_error = target - current; // Initialize previous error
while (liftPIDRunning && fabs(target - current) > 1) {
current = Rotation8.position(deg); // Read current position
double error = target - current; // Calculate error
// Update integral term with anti-windup
if (fabs(integral) < max_speed / ki) {
integral += error;
// Calculate speed based on PID control
double speed = kp * error + ki * integral + kd * (error - previous_error);
// Update previous error for derivative term
previous_error = error;
// Ensure speed is within limits
if (speed > max_speed) {
speed = max_speed;
} else if (speed < -max_speed) {
speed = -max_speed;
} else if (fabs(speed) < min_speed) {
speed = min_speed * direction; // Maintain minimum speed for smooth movement
// Apply speed to the motor
Lift.spin(direction > 0 ? forward : reverse, fabs(speed), percent);
Lift2.spin(direction > 0 ? forward : reverse, fabs(speed), percent);
task::sleep(20); // Delay for stability
Lift.stop(hold); // Stop the motor when target is reached
Lift2.stop(hold);
return 1;
void driverControl(){
while(true){
LeftBottom.spin(vex::directionType::fwd, (Controller1.Axis1.value() + Controller1.Axis3.value()*1.8), vex::velocityUnits::pct);
LeftBack.spin(vex::directionType::fwd, (Controller1.Axis1.value() + Controller1.Axis3.value()*1.8), vex::velocityUnits::pct);
LeftFront.spin(vex::directionType::fwd, (Controller1.Axis1.value() + Controller1.Axis3.value()*1.8), vex::velocityUnits::pct);
RightBottom.spin(vex::directionType::fwd, (Controller1.Axis1.value() - Controller1.Axis3.value()*1.8), vex::velocityUnits::pct);
RightFront.spin(vex::directionType::fwd, (Controller1.Axis1.value() - Controller1.Axis3.value()*1.8), vex::velocityUnits::pct);
RightBack.spin(vex::directionType::fwd, (Controller1.Axis1.value() - Controller1.Axis3.value()*1.8), vex::velocityUnits::pct);
Lift2.setStopping(hold);
ClawRotate.setStopping(hold);
if (hang==1 ){
Hang.set(true);
else if (hang==2 ){
Hang.set(false);
if (Controller1.ButtonA.pressing() && hang == 2){
hang = 1;
vex::task::sleep(150);
if (Controller1.ButtonA.pressing() && hang == 1){
hang = 2;
if(Controller1.ButtonL1.pressing()){
Lift.spin(forward,100, percent);
Lift2.spin(forward,100, percent);
else if(Controller1.ButtonL2.pressing()){
Lift.spin(reverse,100, percent);
Lift2.spin(reverse,100, percent);
else{
Lift.stop();
Lift2.stop();
if(Controller1.ButtonR1.pressing()){
ClawRotate.spin(forward,100, percent);
else{
ClawRotate.stop();
if(Controller1.ButtonRight.pressing()){ //neutral mode
Circuit1.set(false);
//Circuit2.set(false);
if(Controller1.ButtonUp.pressing()){ //open mode
Circuit1.set(true);
//Circuit2.set(true);
if(Controller1.ButtonDown.pressing()){ //closed mode
Circuit1.set(true);
x = 1;
if (tod==1 ){
Mogo.set(true);
else if (tod==2 ){
Mogo.set(false);
if (Controller1.ButtonX.pressing() && tod == 2){
tod = 1;
if (Controller1.ButtonX.pressing() && tod == 1){
tod = 2;
if (Controller1.ButtonR2.pressing() && !liftPIDRunning) {
// Start liftpid task only if it's not already running
target = 278; // Set your desired target
direction = -1; // Set direction based on your setup
vex::task willy_chews(liftpid); // Start the PID task
wait (20, msec);
void Autonomous() {
int main() {
vexcodeInit();
Competition.autonomous(Autonomous);
Competition.drivercontrol(driverControl);
I’m trying to run my lift PID on Button R2 and it is currently running but its movement is wild and it seems to be moving in intervals, it also completely misses its target of 278. I tested this same pid with the same values inside autonomous and it worked flawlessly. Any advice?
edit: code tags added by moderators, please remember to use them.
