I have tried many heavy duty lifting mechanisms on the front and the back of the robot but none of them worked as good as I hoped. I have tried gears, chains, and combinations of both. When I used gears I always tried to have a lot of torque because the weight load exceeded 5-10 pounds. :eek: I have tried to immitate the BottleBot design made by RadioShack, but I could never really make the lifting mechanism work. The BottleBot (http://www.vexlabs.com/vex-bottlebot.shtml) was a good example of the lifting device, but I need different lifting devices. Should I use gear combinations, or will 2 gears per motor work? If you can, please post some images of lifting mechanisms or some other info that would help me.
If possible that’s the way to go. It will give the arm more inertia, but it will make the motors be able to lift things they might not otherwise be able to lift.
