light blink help
im now trying to run a blink sequence when the variable is set to true. heres my code:
task Start_light()
	while(true)
		SensorValue[dgtl1] = true;
		wait1Msec(500);
		SensorValue[dgtl1] = false;
		wait1Msec(500);
task flash2()
			int buttonToggleState = 0;
    int buttonPressed = 0;
	while(1)
		// check for a button press only if we are not already pressed.
		if(vexRT[Btn5U]==1)
			if(!buttonPressed)
				// change the toggle state
				buttonToggleState = 1 - buttonToggleState;
				// Note the button is pressed
				buttonPressed = 1;
		else
			// the button is not pressed
			buttonPressed = 0;
		// Now do something with our toggle flag
		if(buttonToggleState)
			startTask(Start_light);
		else
			stopTask(Start_light);
the problem is that the blink isnt working that way. it stays solid instead of activating the blink sequence
I’m just skimming with very little time. I don’t see any delay in flash2, so you could be starving the other task.
As a separate thing, 500 ms won’t look like a typical blinking light. You’ll want to lower that amount of time. It’s not a right/wrong thing. You’ll just find it’s slow enough that it looks like someone turning on a light and turning it off as opposed to a traditional “blinking.”
it worked fine with its previous two-button on/off setting. the new one-button wont start the cycle
I don’t have the materials with me to test right now, but I believe that because you are (re)starting the task every loop interval, it never stays active long enough to reach the turn-off portion. I would recommend creating a variable, let’s say
taskRunning
, that is set to
true
when
startTask()
is run, and
false
when
stopTask
is run. Then, before running the
startTask()
command, check if
taskRunning
is
true
, and only start the task if it is
false
if (buttonToggleState && !taskRunning) {
    taskRunning = true;
else if (taskRunning) {
    taskRunning = false;
I added a check to the
else
as well because it doesn’t make much sense to stop a task that isn’t running, but I don’t think it’s strictly necessary in RobotC.
