Limit Switch Programming
#21
To add on to what @SkinnyPanda Robotics said, here’s what you would need to do to see the sensor values:
When your robot is turned on and connected to your computer, go to Robot>Open Debugger Manually. While the debugger is open, go to Robot>Debugger Windows>Sensors (I believe that’s what it’s called). This should show a toolbar that displays sensor values on the bottom of the window. What value does the limit switch give when you press it, and the value when you release it?
Hopefully this helps :smiley:
  • [TVA] Connor
#22
all the buttons work. they give an output of 1 when pressed and a 0 when unpressed
