line following with ultrasonic...
I got line following to work and i got ultrasonic to work . How do i get them to work together?
Can, you point your question moreā€¦
How can I make them work together is kind of vague.
I have gotten the line following sensor program working and I have the ultrasonic program working. What i want to know is if there is a way that the two progams could be put into one program together. Basicly, I want my robot to follow a line, then, while on the line, I want the ultrasonic to work as well.
If you simply put drag a ultrasonic block into the first line of your program it will start the ultrasonic. You can also import a function from the help file. I recommend going through the whole getting started section of the help file and you should understand how everything works by the time you finish.
