Here is some working line tracker code. This is EasyC 2.0 code with user derived functions. If you have EasyC 1.0, then whereever you see, for example “TurnLeft()”, copy the code from the TurnLeft function (at the bottom) into that spot. This will also work with the straight MPLAB compiler, which is how I do my programs.
Some notes: I programmed the code to turn 180 degrees and re-aquire the line if it comes to the end. I’ve also added some code that only activates when all three line sensors are hit at once. In my robot, putting a line of tape at right angles to the main line causes the robot to turn 180 degrees and activates a dump mechanism that dumps out whatever is in the hopper (a plastic “in box” type tray) This allows this robot to deliver documents around the office by following lines. I use masking tape over dark gray carpet, so the sensing may be backwards for you if you use electrical tape over tile. Anyway, the logic is:
If left sensor active, go left to center on the line
if right sensor active, go right
if center sensor active, go straight
if no sensors, turn in the direction of the last sensed area. (lastLine variable) This works very well to re-aquire the line and allows the robot to make sharp turns. This same behavior causes the robot to turn 180 degrees if it comes to the end of the line.
This code works better if the sensors are mounted in the front of the robot instead of near the middle.
My robot is a 4-motor tank tread unit, so the right side is motors 1 and 8, which turn backwards, and the left side is 2-7. (this matches the default VEX wiring)
This robot also includes two IRPD (Infrared proximity detectors, Sharp GP2D12 from Acroname Robotics) that work just fine as an analog input. These detect obstacles in the path of the robot. They provide a distance reading.
I also have a button (bumper switch) on the top of the robot labeled “STOP”. Pushing the button switches between radio control mode and autonomous mode. The robot starts in R/C mode and won’t move untill the button is pushed – a very good feature.
#include “UserAPI.h”
#define OUTPUT 0
#define INPUT 1
void GoLeft(void);
void GoRight(void);
void AllStop(void);
void GoForward(void);
void goDump(void);
void IO_Initialization(void)
DefineControllerIO ( 5, INPUT ,INPUT ,INPUT ,INPUT ,INPUT ,INPUT ,INPUT ,INPUT ,INPUT ,INPUT ,OUTPUT ,OUTPUT ,OUTPUT ,OUTPUT ,OUTPUT ,OUTPUT ) ;
int flag; // 0 = auto, 1=RC
int i; // loop counter
int rcInput; // Input from Radio ch 6
int LeftLine; // Input from left line sensor input1
int rightLine; // Input from right Line sensor input 3
int centerLine; // Input from center line sensor
int CamTilt; // Camera Tilt RC
int CamPan; // camera Pan RC
int FWD = 200; // Forward PWM value
int STP = 127; // Stop PWM value
int REV = 55; // Reverse PWM value
int SLOW = 185; // SLOW PWM MODe
int REVSLOW = 80;
int lastLine = 0; // Last Direction of line detected
int min = 200; // lowest IR level detected
int max = 500; // highest IR level detected
int avg = 300; // min-max/2 = trigger IR level
int DumpFlag = 0; // 1 = time to dump!
int IRleft ; // IR Prox detector left
int IRright ; // IR Prox detector right
void main ( void )
i = 0 ;
flag = 1; ; // start in autonomous mode
Wait ( 1000 ) ;
while ( i == 0 ) // infinite loop
if ( flag == 0 ) // if autonomous mode
rcInput = GetDigitalInput ( 9 ) ; // Switch modes
if ( rcInput == 0 ) // switch mode
flag = 1 ; // switch to RC mode
AllStop();
Wait ( 500 ) ; // Debounce the switch
IRleft = GetAnalogInput(4);
IRright = GetAnalogInput(5);
if (IRleft > 200 || IRright > 200) // we see an obstacle
//AllStop();
//Wait(1000);
LeftLine = GetAnalogInput ( 3 ) ;
centerLine = GetAnalogInput ( 2 ) ;
rightLine = GetAnalogInput ( 1 ) ;
if ( rightLine < min )
min = rightLine ;
if ( rightLine > min )
max= rightLine ;
avg = min + ((max-min) / 2) ;
avg = min+200 ;
if ( LeftLine <avg && rightLine < avg && centerLine < avg ) // all sensors activated at once
DumpFlag = 1 ;
GoForward();
Wait ( 400 ) ;
continue;
if ( centerLine < avg )
GoForward();
if ( DumpFlag == 1 )
goDump();
continue;
if ( rightLine < avg ) // if value < 100 then we are over line
GoRight();
lastLine = 1 ; // Last Detected Right Turn
continue;
if ( LeftLine < avg ) // if value > 100 then we are over line
GoLeft();
lastLine = 0 ; // last detected left line
continue;
if ( lastLine == 0 ) // last line detected
SetMotor ( 1 , SLOW ) ;// this is a more agressive turn than a line correction
SetMotor ( 8 , SLOW ) ;
SetMotor ( 2 , FWD ) ;
SetMotor ( 7 , FWD ) ;
continue;
else
SetMotor ( 1 , REV ) ;// more agressive turn
SetMotor ( 8 , REV ) ;
SetMotor ( 2 , REVSLOW ) ;
SetMotor ( 7 , REVSLOW ) ;
continue;
}// end of IF FLAG==0 block i.e. autonomous mode
else // // rc mode
Arcade4 ( 0 , 2 , 1 , 1 , 2 , 8 , 7 , 0 , 0 , 0 , 0 ) ;
MotorRcControl ( 0 , 6 , 6 , 0 ) ;
ServoRcControl ( 0 , 4 , 4 , 0 ) ;
ServoRcControl ( 0 , 3 , 3 , 0 ) ;
rcInput = GetDigitalInput ( 9 ) ; // switch modes
if ( rcInput ==0 )
flag = 0 ; // switch to autonomous mode
void GoLeft()
SetMotor ( 2 , SLOW ) ;
SetMotor ( 7 , SLOW ) ;
SetMotor ( 1 , 127 ) ;
SetMotor ( 8 , 127 ) ;
return;
void GoRight()
SetMotor ( 1 , REVSLOW ) ;
SetMotor ( 8 , REVSLOW ) ;
SetMotor ( 2 , 127 ) ;
SetMotor ( 7 , 127 ) ;
return;
void AllStop()
SetMotor(1,127);
SetMotor(2,127);
SetMotor(7,127);
SetMotor(8,127);
return;
void GoForward()
SetMotor(1,REV);
SetMotor(8,REV);
SetMotor(7,FWD);
SetMotor(2,FWD);
void goDump()
int enc = 0; // encoder value
DumpFlag = 0 ;
AllStop();
SetMotor ( 6 , 0 ) ;
StartEncoder(1);
enc = 0;
PresetEncoder(1,0);
while (enc <= 25)
enc = GetEncoder(1);
SetMotor ( 6 , 127 ) ;
Wait(2000); // hold still, wait for paper to dump out
SetMotor ( 6 , 255 ) ;
enc = 0;
StartEncoder(1);
PresetEncoder(1,0);
while (enc <= 25)
StopEncoder(1);
return;
