line tracker easyc 1.1
I have easyc 1.1 for programing my vex kit, but i can’t figure out how to get my 3 linetrackers working. So could someone post the linetracker file?
A working version of the linetracker code is already posted here, as well as the related discussion.
There are also pictures of our tracker robot in the gallery, and a YouTube of it in action.
Cheers,
  • Dean
i have easyc 1.1 and the code will not work
Ahh, right. I suppose I could post screenshots of the code so you can re-create it…
  • Dean
EasyC 1.x does not have the ability to to create User Functions within EasyC. You will need to either write ALL the code Inline, or Create your own User Functions and call them with EasyC 1.x User Code command.
Main Header File
#ifndef _main_h_
#define _main_h_
#include "UserAPI.h"
#define RUN_SPEED   127
#define SPIN_SPEED  96
#define VEER_SPEED  64
#define STOP    1
#define GO  0
#define BLACK   1
#define WHITE   0
#define RIGHT   1
#define LEFT    0
extern int LastBlack ;
extern int Threshold ;
int Track_Line ( void ) ;
void Left_Speed ( int speed ) ;
void Right_Speed ( int speed ) ;
#endif // _main_h_
Main Code
#include "Main.h"
void main ( void )
      int Stop = 1;
      int Buttons = 127;
      while ( 1 ) // Loop Forever
            Buttons = GetRxInput ( 1 , 5 ) ;
            if ( Buttons < 50 )
                  Stop = STOP ;
                  SetMotor ( 8 , 127 ) ; // Turn Lamp Off
                  SetDigitalOutput ( 11 , 0 ) ; // Turn LED Off
            else if ( Buttons >200 )
                  Stop = GO ;
                  SetMotor ( 8 , 255 ) ; // Turn Lamp On
                  SetDigitalOutput ( 11 , 1 ) ; // Turn LED On
                  Threshold = GetAnalogInput ( 4 ) ;
            if ( Stop )
                  Tank2 ( 0 , 3 , 2 , 3 , 2 , 0 , 1 ) ; // Standard 23 Tank Mode
            else
                  Stop = Track_Line ( ) ;
                  if ( Stop == 1 )
                        Left_Speed ( 0 ) ;
                        Right_Speed ( 0 ) ;
Track Line
#include "Main.h"
      int Right = 0;
      int Left = 0;
      int Center = 0;
      Right = GetAnalogInput ( 1 ) ;
      Left = GetAnalogInput ( 2 ) ;
      Center = GetAnalogInput ( 3 ) ;
      Right = Right > Threshold ; // 1=Black, 0=White
      Left = Left > Threshold  ; // 1=Black, 0=White
      Center= Center > Threshold ; // 1=Black, 0=White
      if ( Center == WHITE ) // Center sees White!  Need to Steer
            if ( Right == BLACK ) // Need to steer right
                  Left_Speed ( SPIN_SPEED ) ;
                  Right_Speed ( 0 ) ;
                  LastBlack = RIGHT ;
            else if ( Left == BLACK ) // Need to steer left
                  Left_Speed ( 0 ) ;
                  Right_Speed ( SPIN_SPEED ) ;
                  LastBlack = LEFT ;
            else // All White - need to hunt!
                  if ( LastBlack == RIGHT ) // Need to hunt right
                        Left_Speed ( VEER_SPEED ) ;
                        Right_Speed ( -SPIN_SPEED ) ;
                  else // Need to hunt left
                        Left_Speed ( -SPIN_SPEED ) ;
                        Right_Speed ( VEER_SPEED ) ;
      else // Center sees Black
            if ( (Right == BLACK) && (Left == BLACK) ) // All Three Black!  Need to hunt
                        Right_Speed ( -VEER_SPEED ) ;
                        Left_Speed ( -VEER_SPEED ) ;
            else
                  if ( Right == BLACK ) // Line is on Right, need to veer right
                        LastBlack = RIGHT ;
                  else if ( Left == BLACK ) // Line is on Left, need to veer left
                        LastBlack = LEFT ;
                  else // Line is dead center - full speed ahead!
      return GO ;
Left Speed
#include "Main.h"
{ // Left motor speed (-127..0..127)
      SetMotor ( 3 , 127+speed ) ;
Right Speed
#include "Main.h"
{ // Right motor speed (-127..0..127)
      SetMotor ( 2 , 127-speed ) ;
Yep - the code that matters is all in Track_Line(), which can simply become main(). The original main() just has code to turn line-tracking on and off, which isn’t really necessary.
You’ll need to make sure to set Threshold to a sensible value, though. I read it from a potentiometer so it could easily be adjusted, but we never needed to change it. Just pick a value that is half way between the dark and light readings you get from your line sensors.
Also, Left_Speed() and Right_Speed() can be easily eliminated by just inserting each function’s code wherever they were called.
Those changes will easily get you down to a single block of code.
Cheers,
  • Dean
I forgot the DEFINES in the Header File… Added Now…
A very simple one-sensor line tracker and program are given in both the documents Vex Machinations or Vex for the Technically Challenged, posted here:
http://www.vexrobotics.com/vex-education-general-resources.shtml
