LineTracker Sensor reporting
I’m trying to calibrate my line tracker by find the threshold value using this code, but what reports back is 2^32 (4294967296 ) for both percentage and analog. What does that mean?
My code:
while(true) {
Brain.Screen.clearScreen();
// display the line sensor percent value on the screen
Brain.Screen.printAt(1, 20, "percent: %f %%", LineTrackerH.value(percentUnits::pct));
Brain.Screen.printAt(1, 40, "analog: %f mV", LineTrackerH.value(analogUnits::mV));
//Sleep the task for a short amount of time to prevent wasted resources.
task::sleep(10);
@djuncle hi! did you guys ever figure this out? we have the same problem :confused:
use %d rather than %f for the print format, both those methods return integers not floating point numbers.
