Looking for servo motor to VEX gear connection
I’m looking for a piece that would connect a square hole gear such as one of these
to a servo motor head such as this one
http://ep.yimg.com/ca/I/yhst-62196343123315_2273_64874354
What is the best way to connect the two?
Thank You!
If you feel like getting creative, and ensuring a solid bond, you could always 3D print a custom insert. that has a connector to the servo.
User something like this.
https://www.servocity.com/html/servo_to_shaft_couplers.html#.Vvbs_8coWEI
With a shaft coupler.
jpearman,
I couldn’t find the outside diameter of the VEX shaft coupler. This would work great for me but I need that spec in order to pick a servo to shaft coupler.
I will measure it for you on Monday when I’m back home.
That would be extremely helpful, thank you!
The shaft couplers are around 1/4" or 6.3mm
