The following statement is marked with a red x: void waitForRelease()
Compiler Error states: *Error : Functions must be defined at main scope level
Any ideas on how to fix?
WildCats
WildCats
Are you trying to declare this function inside of another function? It would help if we could see the code.
Are you declaring your function in
task main() {}
? It should be defined outside of there.
How would I define this outside of task main?
Function header and body outside task main, like this:
// motor/sensor setup blah blah blah
void waitForRelease() {
//code
task main () {
//code
