Make It Real CAD Engineering Challenge Question
I found a problem: the version of fusion 360 that is available under the educational license is fusion 360, but the online challenge info says “You must use Autodesk Fusion 360 Ultimate and/or Autodesk Inventor Professional.” Will this be a problem for the online challenge?
Yes, the version of Fusion 360 available under the educational free license is the same standard software used in the professional realm. It seems the names of software packages change often, so this is a great question. We will clarify the challenge wording by removing “Ultimate,” as it is the same package. Good luck!
