Make process closed with exit code :2
Hey, I’m new to C++ and I’m struggling to find out what’s wrong with my code. I’ve been looking at the forum and it seems to be something with the main src but I have no idea what to do about it. I’d really appreciate it if someone could explain to me what’s wrong! :slight_smile:
When I build the code, it does this:
[info]: Saving Project ...
[info]: Project saved!
windows build for platform vexv5
"CXX src/main.cpp"
"LINK build/3767X-V1-Comp-uhh.elf"
build/src/robot-config.o:(.bss.Brain+0x0): multiple definition of `Brain'
build/src/main.o:(.bss.Brain+0x0): first defined here
make: *** [vex/mkrules.mk:18: build/3767X-V1-Comp-uhh.elf] Error 1
[error]: make process closed with exit code : 2
/*    Module:       main.cpp                                                  */
/*    Author:       VEX                                                       */
/*    Created:      Thu Sep 26 2019                                           */
/*    Description:  Competition Template                                      */
// Robot Configuration:
// [Name]               [Type]        [Port(s)]
// Drivetrain           drivetrain    1, 2
// ArmL                 motor         3
// ArmR                 motor         4
// ZuccL                motor         5
// ZuccR                motor         6
// LiftyBoi             motor         7
// Controller1          controller
#include "vex.h"
using namespace vex;
competition Competition;
brain  Brain;
// VEXcode device constructors
motor LeftDriveSmart = motor(PORT1, ratio18_1, false);
motor RightDriveSmart = motor(PORT2, ratio18_1, true);
drivetrain Drivetrain = drivetrain(LeftDriveSmart, RightDriveSmart, 319.19, 16.002, 130, mm, 1);
motor ArmL = motor(PORT3, ratio18_1, false);
motor ArmR = motor(PORT4, ratio18_1, false);
motor ZuccL = motor(PORT5, ratio18_1, false);
motor ZuccR = motor(PORT6, ratio18_1, true);
motor LiftyBoi = motor(PORT7, ratio18_1, false);
controller Controller1 = controller(primary);
// VEXcode generated functions
// define variables used for controlling motors based on controller inputs
bool Controller1LeftShoulderControlMotorsStopped = true;
bool Controller1RightShoulderControlMotorsStopped = true;
bool Controller1XBButtonsControlMotorsStopped = true;
bool DrivetrainLNeedsToBeStopped_Controller1 = true;
bool DrivetrainRNeedsToBeStopped_Controller1 = true;
/*                          Pre-Autonomous Functions                         */
/*  You may want to perform some actions before the competition starts.      */
/*  Do them in the following function.  You must return from this function   */
/*  or the autonomous and usercontrol tasks will not be started.  This       */
/*  function is only called once after the V5 has been powered on and        */
/*  not every time that the robot is disabled.                               */
void pre_auton(void) {
  vexcodeInit();
/*                              Autonomous Task                              */
/*  This task is used to control your robot during the autonomous phase of   */
/*  a VEX Competition.                                                       */
/*  You must modify the code to add your own robot specific commands here.   */
void autonomous(void) {
  // Insert autonomous user code here.
/*                              User Control Task                            */
/*  This task is used to control your robot during the user control phase of */
void usercontrol(void) {
  while (1) {
    // This is the main execution loop for the user control program.
    // Each time through the loop your program should update motor + servo
    // values based on feedback from the joysticks.
    // Insert user code here. This is where you use the joystick values to
    // update your motors, etc.
    int drivetrainLeftSideSpeed = Controller1.Axis3.position();
    int drivetrainRightSideSpeed = Controller1.Axis2.position();
    // check if the value is inside of the deadband range
    if (drivetrainLeftSideSpeed < 5 && drivetrainLeftSideSpeed > -5) {
      // check if the left motor has already been stopped
      if (DrivetrainLNeedsToBeStopped_Controller1) {
        // stop the left drive motor
        LeftDriveSmart.stop();
        // tell the code that the left motor has been stopped
        DrivetrainLNeedsToBeStopped_Controller1 = false;
    } else {
      // reset the toggle so that the deadband code knows to stop the left motor next time the input is in the deadband range
    if (drivetrainRightSideSpeed < 5 && drivetrainRightSideSpeed > -5) {
      // check if the right motor has already been stopped
      if (DrivetrainRNeedsToBeStopped_Controller1) {
        // stop the right drive motor
        RightDriveSmart.stop();
        // tell the code that the right motor has been stopped
        DrivetrainRNeedsToBeStopped_Controller1 = false;
    } else {
      // reset the toggle so that the deadband code knows to stop the right motor next time the input is in the deadband range
    // only tell the left drive motor to spin if the values are not in the deadband range
      LeftDriveSmart.setVelocity(drivetrainLeftSideSpeed, percent);
      LeftDriveSmart.spin(forward);
    // only tell the right drive motor to spin if the values are not in the deadband range
      RightDriveSmart.setVelocity(drivetrainRightSideSpeed, percent);
      RightDriveSmart.spin(forward);
    // check the ButtonL1/ButtonL2 status to control ArmL
    if (Controller1.ButtonL1.pressing()) {
      ArmL.spin(forward);
      Controller1LeftShoulderControlMotorsStopped = false;
    } else if (Controller1.ButtonL2.pressing()) {
      ArmL.spin(reverse);
    } else if (!Controller1LeftShoulderControlMotorsStopped) {
      ArmL.stop();
      // set the toggle so that we don't constantly tell the motor to stop when the buttons are released
    // check the ButtonR1/ButtonR2 status to control ZuccL
    if (Controller1.ButtonR1.pressing()) {
      ZuccL.spin(forward);
      Controller1RightShoulderControlMotorsStopped = false;
    } else if (Controller1.ButtonR2.pressing()) {
      ZuccL.spin(reverse);
    } else if (!Controller1RightShoulderControlMotorsStopped) {
      ZuccL.stop();
    // check the X/B buttons status to control LiftyBoi
    if (Controller1.ButtonX.pressing()) {
      LiftyBoi.spin(forward);
      Controller1XBButtonsControlMotorsStopped = false;
    } else if (Controller1.ButtonB.pressing()) {
      LiftyBoi.spin(reverse);
    } else if (!Controller1XBButtonsControlMotorsStopped){
      LiftyBoi.stop();
    // wait before repeating the process
    wait(20, msec);
                    // prevent wasted resources.
// Main will set up the competition functions and callbacks.
int main() {
  // Set up callbacks for autonomous and driver control periods.
  // Run the pre-autonomous function.
  pre_auton();
  // Prevent main from exiting with an infinite loop.
  while (true) {
    wait(100, msec);
your brain is defined twice. It is done automatically in robot-config.cpp, so you don’t have to do it again in main.cpp.
It’s under the comment // define your global instances of motors and other devices here and looks like brain Brain;. Just delete that and you should be good to go.
Also just so you know, all ‘make process closed with error code: 2’ means is ‘this code has errors.’ The real error is listed in the log here:
