This error message is only appearing after I moved my teams driver control code into the competition template but it doesn’t happen in it’s own individual file. the error is showing for the curly brace just after void finesse() and just after int main().
here is the error message
[info]: Saving Project …
[info]: Project saved!
windows build for platform vexv5
“CXX src/main.cpp”
src/main.cpp:88:1: error: function definition is not allowed here
src/main.cpp:101:12: error: function definition is not allowed here
int main() {
2 errors generated.
make: *** [vex/mkrules.mk:13: build/src/main.o] Error 1
[error]: make process closed with exit code : 2
below here is the code for the robot, only worry about the driver control section I copy pasted it all just in case.
/* Module: main.cpp */
/* Author: VEX */
/* Created: Thu Sep 26 2019 */
/* Description: Competition Template */
// Robot Configuration:
// [Name] [Type] [Port(s)]
// FR motor 10
// FL motor 1
// BR motor 9
// BL motor 2
// Controller1 controller
#include "vex.h"
using namespace vex;
competition Competition;
/* Pre-Autonomous Functions */
/* You may want to perform some actions before the competition starts. */
/* Do them in the following function. You must return from this function */
/* or the autonomous and usercontrol tasks will not be started. This */
/* function is only called once after the V5 has been powered on and */
/* not every time that the robot is disabled. */
void pre_auton(void) {
vexcodeInit();
/* Autonomous Task */
/* This task is used to control your robot during the autonomous phase of */
/* a VEX Competition. */
/* You must modify the code to add your own robot specific commands here. */
void autonomous(void) {
// Insert autonomous user code here.
/* User Control Task */
/* This task is used to control your robot during the user control phase of */
void usercontrol(void) {
while (1) {
// This is the main execution loop for the user control program.
// Each time through the loop your program should update motor + servo
// values based on feedback from the joysticks.
int X2 = 0;
int Y1 = 0;
int X1 = 0;
int threshold = 10;
int F = 0;
void finesse()
if (F==0)
F = 1;
else
F = 0;
int main() {
vexcodeInit();
Controller1.ButtonLeft.pressed(finesse);
while (1)
float Ch1 = Controller1.Axis1.position();
float Ch2 = Controller1.Axis2.position();
float Ch3 = Controller1.Axis3.position();
float Ch4 = Controller1.Axis4.position();
if(fabs(Ch2) > threshold)
Y1 = Ch2;
else
Y1 = 0;
if(fabs(Ch1) > threshold)
X1 = Ch1;
else
X1 = 0;
if(fabs(Ch4) > threshold)
X2 = Ch4;
else
X2 = 0;
if (F==1)
FR.spin(fwd, .5*(Y1-X2-X1), pct);
BR.spin(fwd, .5*(Y1-X2+X1), pct);
FL.spin(fwd, .5*(Y1+X2+X1), pct);
BL.spin(fwd, .5*(Y1+X2-X1), pct);
else
FR.spin(fwd, Y1-X2-X1, pct);
BR.spin(fwd, Y1-X2+X1, pct);
FL.spin(fwd, Y1+X2+X1, pct);
BL.spin(fwd, Y1+X2-X1, pct);
// prevent wasted resources.
// Main will set up the competition functions and callbacks.
int main() {
// Set up callbacks for autonomous and driver control periods.
// Run the pre-autonomous function.
pre_auton();
// Prevent main from exiting with an infinite loop.
while (true) {
wait(100, msec);
edit: code tags added by mods
