Why not switch all of the vex electronics to female pin holes and then use double ended male pwm wires? I don’t feel that I need to explain why this would be a great idea.
because then in order to extend them you still need male to female cables
@PixelToast That is a potential problem, but you’re only supposed to use a single extension per wire, also more cables are still cheaper than replacing broken electronics.
How about cables like I2C (male-female, pins embedded in cap)?
They are actually very easy to repair; these are the products I use. You can slip the pin out of the housing by lifting the tab with a razor knife and pull the wire out.
link text
link text
link text
