Marble Sorter code help
my partner and I are finishing our marble sorter for a final grade in our PoE class we have the hardware portion pout together and some of the code has been put together, but the line follower and finishing motor wont work here’s the code and a picture of the hardware
#pragma config(Sensor, in1, cupReader, sensorPotentiometer)
#pragma config(Sensor, in2, marbleSorter, sensorLineFollower)
#pragma config(Sensor, dgtl1, startButton, sensorTouch)
#pragma config(Motor, port2, sorterGear, tmotorVex393HighSpeed_MC29, openLoop)
#pragma config(Motor, port3, cupGears, tmotorVex393HighSpeed_MC29, openLoop)
#pragma config(Motor, port4, startServo, tmotorServoStandard, openLoop)
Project Title: Marble Sorter
Team Members:Colton M. Gabe W.
Date:3/28/19
Task Description: Create a machine that can determine the difference in 4 different marbles when inserted into the machine.
//Funtion Declarations
void moveMarbles();
void sortMarbles();
task main()
moveMarbles();
sortMarbles();
void moveMarbles()
while(1==1)
motor[startServo]=-127;
wait1Msec(1000);
motor[startServo]=127;
wait1Msec(5000);
void sortMarbles()
while(1==1)
	if(SensorValue(marbleSorter)>2044)		//if the marble is opaque
		if(SensorValue(cupReader)==4095)		//if the wood cup is under the reader
			while(SensorValue(cupReader)!= 0)		//while the cup under the reader is not the opaque cup
				motor[cupGears]=20;								//move motor
			motor[sorterGear]=20;			//let the marble go
			wait1Msec(500);						//wait half sec
			motor[sorterGear]=0;			//stop motor
			motor[sorterGear]=-20;		//reset marble stopping gear
		else if(SensorValue(cupReader)==2070)		//if the aluminium cup is under the reader
				motor[cupGears]=-20;						//move motor
		else										//if the cup under reader is opaque cup
	else if(SensorValue(marbleSorter)<2100 && SensorValue(marbleSorter)>1388) //determines if the marble is aluminium
		if(SensorValue(cupReader)==0)						//if the cup under reader is opaque
			while(SensorValue(cupReader)!= 2070)		//while the cup under reader is not wood
		else if(SensorValue(cupReader)==4095)			//if the cup under the reader is
				motor[cupGears]=20;
			wait1Msec(500);
			wait1Msec(500);
			wait1Msec(500);
		else
			wait1Msec(500);
			wait1Msec(500);
			wait1Msec(500);
	else										//if marble is wood
			while(SensorValue(cupReader)!= 4095)
				motor[cupGears]=20;
			wait1Msec(500);
			wait1Msec(500);
			wait1Msec(500);
				motor[cupGears]=20;
			wait1Msec(500);
			wait1Msec(500);
			wait1Msec(500);
		else
			wait1Msec(500);
			wait1Msec(500);
			wait1Msec(500);
Moved this to the EDR category.
The first problem I could see in your code is that once main task calls moveMarbles() function the control will never come back and will keep looping inside while(1==1) loop.
So sortMarbles() function is never called.
What you want to do instead is to have a one main loop inside the main task and then call from it short functions that will always return:
task main()
   while(true)  // this is the main loop
     letMarbleToTheSensor(); // whatever steps are necessary to get marble to the sensor
     int s = SensorValue(marbleSorter);
     if( s>500 && s<800 ) // particular marble type
         moveCups(1000);
     else if( s>1000 && s<1800 ) // another marble type
         moveCups(2000);
     // etc ...
     letMarbleThrough(); // drop marble into the cup
     wait1Msec(10);
@technik3k
so we have our code working for the most part, but we forgot that we have to include a stop after 16 run throughs, so we tried to add a for loop, but it wont work
for(int counter=0; counter<=16; counter ++) this is what we have then everything else is after inside parenthesis
@gabewells903, it is great that your marble sorter works!
But why wouldn’t a simple for() loop count the marbles?
Did it fail work at all or it just didn’t count properly?
In any case, here is how I usually do this type of the loops:
int marbleCounter = 0;
    if( s in some expected range ) // marble of one of the types is detected
        marbleCounter++;           // only increment the counter when marble is detected
        moveCups(somePosition);
    else if(...)
    if( marbleCounter > theNumber )
        break; // this will jump out of the loop and end the program
    wait1Msec(10);
The trick is to increment the marbleCounter only when you detect the marble and only once per cycle. You will be counting how many times you had detected the marble and moved the cups to catch it.
After “break” statement exits “while(true){}” loop you will need to reset the power to restart the program. An alternative solution may be to add a button and wait until it is pressed instead of breaking out of the loop.
A little tip with the markdown on here, if you put 3 grave symbols above and below your code it will keep its formatting.
Example:
//Code here
becomes
//Code here
Discourse also supports BBCode in addition to Markdown:
One pager Markdown reference: Markdown Reference
So the [code] [/code] tag will work as well:
[code]
int counter=0;
while(true)
   read_Markdown_specification();
   if( am_I_feeling_stupid() == true )
       counter++;
   else
       break;
printf("Counter value for %s = %d", getUserName(), counter);
[/code]
Counter value for technik3k = 99
