Matchload worth it for a chainbar?
Hi, so our robot has a chainbar with a horizontal claw intake and it can stack 11 cones max. Would it be worth it to develop a match load automation or should we just stay to picking up cones off the ground? I’m particularly worried about rule <SG3>.
um, what specifically about this rule are you worried about?
also, a chainbar’s greatest strength is that it easily fields cones and quickly build stacks of 5-6. Along with the arcing nature of the chainbar, I think it’s better to stick to fielding
My chainbar can match load. If you have specific questions pm me. There’s no rule to be worried about.
My last robot was a chain bar, and the only thing we could do well was match loads. We could field with it, but match loads were easier
Well cuz on our robot we have to press the cone into the claw to make it close and grab the cone correctly and according to that rule its illegal.
Yeahhhhh that’s a mechanical issue
yeah uh, I think you want a different claw design if that’s the case because that also sounds like an issue when fielding.
Actually I think it helps for fielding. The driver doesn’t have to position the claw super precisely, they just drive into the cone and grab it. It really is just a stopper to prevent the cone from tipping over when the driver goes in to grab it.
I think at this point we’re seeing bots that are optimized for fielding (7700r, 6007x) allianced with robots that are able to do preloads and stationary goals - whatever is faster. Keep in mind that the minute you take a cone off the field, it’s yours and the opponent can’t take that cone anymore.
