Mating High Strengh Gears
How do I mate a high strength gear. I cant find any surfaces that line up a gear with a c channel
What platform are you using?
Im using inventor
20 characters
I use fusion so not sure how this translates but try making a 2d circle on the center of the gear, and constraining to that
If you use the c-channels from the SIGBot’s library they have work axes through the center of each hole that you can easily constrain to the axes you want on the gears.
damn thanks i didnt know that existed
