Max Speed Using PCTs
What is the highest number I can set the velocity Units to in PCTs. 100?
Yes sir 100 is max speed for percent.
On a side note, doing a higher value will cause it to just use 100 when the code runs. You also have negative 100 though so it is more like ±100.
Get rid of voltage limiter and turn it up to 9000%
See for yourself
