A question was recently asked in the official Q&A.
The answer from VEX tech support is as follows.
Not to nit pick, but this answer first says that it’s OK for the voltage to drift above the 12V spec by “a few volts” and then says that 15V will damage the cortex. I guess 3V is more than a few volts. A real spec with qualification would be useful.
In this thread I discussed the power distribution in the cortex as I understood it.
https://vexforum.com/showpost.php?p=326053&postcount=1
There are two main 5V power regulators running from the input power. The LM2940 datasheet shows maximum input as 26V, the L5973D has a maximum input of 36V, however we have no idea of the rating of the surrounding components. A typical value for capacitors used in this application may be 16V so I suspect anything above that would cause harm and would be the reason why the spec for the cortex has maximum input at 12V.
Another consideration has to be motors that may be connected to the cortex. The spec given for these is when they are driven at a nominal 7.2V and I’m not sure I would want to run them (continuously) much beyond 9V without more information. Input power to the cortex is fed directly to the motor ports and is a good reason not to be powering the cortex from 12V.
Bottom line is that a 9V bench supply would be more suitable and ideally an adjustable one set for 7.2V.
