Mechanum Wheels moving jittery:
So in our program, we just added the triggers to make our base go side to side, however it seems very jittery and is doing the same on the joysticks now for whatever reason. It works fine in autonomous
 task usercontrol()
	bLCDBacklight = true;									// Turn on LCD Backlight
	string mainBattery, backupBattery;
	while (true)
		clearLCDLine(0);											// Clear line 1 (0) of the LCD
		clearLCDLine(1);											// Clear line 2 (1) of the LCD
		//Display the Primary Robot battery voltage
		displayLCDString(0, 0, "Primary: ");
		sprintf(mainBattery, "%1.2f%c", nImmediateBatteryLevel/1000.0,'V'); //Build the value to be displayed
		displayNextLCDString(mainBattery);
		motor[port3] = vexRT[Ch3];
		motor[port5] = vexRT[Ch3];
		motor[port2] = vexRT[Ch2];
		motor[port4] = vexRT[Ch2];
		motor[port1] = vexRT[Ch3Xmtr2];
		motor[port10] = vexRT[Ch3Xmtr2];
		if(vexRT[Btn5UXmtr2] == 1) // center wheel button 5U
			motor[port7] = -100;
			motor[port6] = -100;
			motor[port8] = -100;
			motor[port9] = -100;
		else if(vexRT[Btn5DXmtr2] == 1)
			motor[port7] = -95;
			motor[port6] = -95;
			motor[port8] = -95;
			motor[port9] = -95;
		else {
			motor[port6] =0;
			motor[port7] =0;
			motor[port8] =0;
			motor[port9] =0;
		if(vexRT[Btn6UXmtr2] == 1) // center wheel button 5U
			motor[port7] = -90;
			motor[port6] = -90;
			motor[port8] = -90;
			motor[port9] = -90;
		else if(vexRT[Btn6DXmtr2] == 1)
			motor[port7] = -85;
			motor[port6] = -85;
			motor[port8] = -85;
			motor[port9] = -85;
		else
			motor[port6] =0;
			motor[port7] =0;
			motor[port8] =0;
			motor[port9] =0;
		if(vexRT[Btn5U] == 1) // center wheel button 5U
			motor[port3] =127;
			motor[port5] =-127;
			motor[port2] =-127;
			motor[port4] =127;
		else if(vexRT[Btn6U] == 1)
			motor[port3] =-127;
			motor[port5] =127;
			motor[port2] =127;
			motor[port4] =-127;
		else
			motor[port3] =0;
			motor[port5] =0;
			motor[port2] =0;
			motor[port4] =0;
/* This is all the remote control commands and also has the command, that displays our main battery voltage and turns on the LCD backlight */
See this thread (post #4, Stop your motors jittering)
https://vexforum.com/t/robotc-bad-programming-habits/28357/1
