Hi, I wasn’t sure if it was appropriate to go into an old post or make a new one but from reading other posts I think I just have a stupid error in my code. I’m not exactly sure what I’m doing wrong but I keep getting a memory permission error. The goal of this code is just in autonomous for the indexer to run until the condition of the line sensor is met and to stop.
/* Module: main.cpp */
/* Author: VEX */
/* Created: Thu Sep 26 2019 */
/* Description: Competition Template */
#include "vex.h"
using namespace vex;
competition Competition;
vex::motor LeftMotor = vex::motor( vex::PORT11,true );
vex::motor BackLeftMotor = vex::motor( vex::PORT12,true );
vex::motor_group LDrive = vex::motor_group(LeftMotor,BackLeftMotor);
vex::motor RightMotor = vex::motor( vex::PORT20,false );
vex::motor BackRightMotor = vex::motor( vex::PORT19,false );
vex::motor_group RDrive = vex::motor_group(RightMotor,BackRightMotor);
vex::motor_group Drive = vex::motor_group(LeftMotor,BackLeftMotor,RightMotor,BackRightMotor);
vex::motor Intake = vex::motor(vex::PORT13,true );
vex::motor Intake2 = vex::motor(vex::PORT17,false);
vex::motor_group Intakes = vex::motor_group(Intake,Intake2);
vex::motor Index = vex::motor(vex::PORT18,false );
vex::motor Index2 = vex::motor(vex::PORT14,false);
vex::motor_group Indexer = vex::motor_group(Index,Index2);
vex::controller Controller1 = vex::controller(vex::controllerType::primary);
vex::controller Controller2 = vex::controller(vex::controllerType::partner);
triport ThreeWirePort = vex::triport( vex::PORT22 );
vex::line LineA = vex::line(Brain.ThreeWirePort.A);
vex::line LineB = vex::line(Brain.ThreeWirePort.B);
int noball;
int noball2;
int noball3;
void wait(float mSec){
vex::task::sleep(mSec);
void autosort(){
while (true ){
if (LineB.value(analogUnits::pct) <= noball - 30 ){
Indexer.stop();
else {
Index.spin(forward,100,pct);
Index2.spin(reverse,100,pct);
/* Pre-Autonomous Functions */
/* You may want to perform some actions before the competition starts. */
/* Do them in the following function. You must return from this function */
/* or the autonomous and usercontrol tasks will not be started. This */
/* function is only called once after the V5 has been powered on and */
/* not every time that the robot is disabled. */
void pre_auton(void) {
noball2 = LineA.value(analogUnits::pct);
noball3 = LineB.value(analogUnits::pct);
vexcodeInit();
/* Autonomous Task */
/* This task is used to control your robot during the autonomous phase of */
/* a VEX Competition. */
/* You must modify the code to add your own robot specific commands here. */
void autonomous(void) {
autosort();
//Drive.rotateFor(-800, vex::rotationUnits::raw, 70, vex::velocityUnits::pct,true);//Drives forward to turn
/* User Control Task */
/* This task is used to control your robot during the user control phase of */
void usercontrol(void) {
while (1) {
// This is the main execution loop for the user control program.
// Each time through the loop your program should update motor + servo
// values based on feedback from the joysticks.
// Insert user code here. This is where you use the joystick values to
// update your motors, etc.
// prevent wasted resources.
// Main will set up the competition functions and callbacks.
int main() {
// Set up callbacks for autonomous and driver control periods.
autosort();
// Run the pre-autonomous function.
pre_auton();
// Prevent main from exiting with an infinite loop.
while (true) {
wait(100, msec);
