After updating vex code v5 text and the brain I now get a memory permission error. The error is 038011B0
Check your code if the variables you made are colored yellow. if it is than it could be causing the problem.
like this:
just make the variable a capital letter like the variable under it (the bad one).
if not make sure your brain is updated and try re-downloading.
see this
Certain errors won’t be picked up by the editor could be causing this. I’ve gotten memory permission errors when unintentionally using nil values. I’ve also had this happen when the program didn’t completely download.
