Hello world! Beginner programmer here.
I’ve been trying to fix a problem that occurs when i try to run my code on my brain - Memory Permission error 03801470.
I tried looking it up on google, but there was a grand total of four results, none of which speak of the programming language I’m using (C++).
Does anyone know how I can fix this?
Here’s my program
/* Module: main.cpp */
/* Author: C:\Users\Robotics */
/* Created: Wed Oct 11 2023 */
/* Description: V5 project */
// Robot Configuration:
// [Name] [Type] [Port(s)]
// Controller1 controller
// Catapult motor 16
// Wings motor_group 17, 18
// Rollah motor 19
// Left motor_group 12, 13
// Right motor_group 14, 15
#include "vex.h"
using namespace vex;
//other variables
double TurnVal = Controller1.Axis3.position(percent);
double TurnVolts = TurnVal * 0.12;
//settings
double kP = 0.0;
double kI = 0.0;
double kD = 0.0;
double TurnkP = 0.0;
double TurnkI = 0.0;
double TurnkD = 0.0;
//autonomous settings
int desiredPosition = 200;
int desiredTurnValue = 0;
int Error;
// Error = sensor value - desired value : position -> speed -> accel
int prevError = 0;
// Position 20 miliseconds ago
int Derivative;
// Error - prevError : speed
int TotalError = 0;
int TurnError;
int prevTurnError = 0;
int TurnDerivative;
int TotalTurnError = 0;
bool ResetDrive = false;
bool enableDrivePID = true;
int drivePID(){
while (enableDrivePID){
if (ResetDrive){
ResetDrive = false;
Left.setPosition(0,degrees);
Right.setPosition(0,degrees);
//Lateral PID
// position of the motors
int leftMotorPosition = Left.position(degrees);
int rightMotorPosition = Right.position(degrees);
// average position of the motors
int averageMotorPosition = (leftMotorPosition + rightMotorPosition)/2;
// potential
Error = averageMotorPosition - desiredPosition;
// derivative
Derivative = Error - prevError;
// absement
TotalError += Error;
double LateralMotorPower = Error * kP + Derivative * kD + TotalError * kI;
Left.spin(forward, LateralMotorPower + TurnVolts, voltageUnits::volt);
Left.spin(forward, LateralMotorPower - TurnVolts, voltageUnits::volt);
//Turn PID
int turnDifference = leftMotorPosition - rightMotorPosition;
// potential
TurnError = turnDifference - desiredTurnValue;
// derivative
TurnDerivative = TurnError - prevTurnError;
// Integral
//TotalError += TurnError;
double turnMotorPower = TurnError * TurnkP + TurnDerivative * TurnkD + TotalError * kI;
// program (duh)
prevError = Error;
vex::task::sleep(20);
return 1;
void autonomous(void) {
vex::task proot(drivePID);
ResetDrive = true;
int main() {
vexcodeInit();
//Auto win points
//Manual control
while (1) {
//Driving
Left.spin(forward, Controller1.Axis3.value(), percent);
Right.spin(forward, Controller1.Axis2.value(), percent);
wait(20, msec);
if(Controller1.ButtonR1.pressing()){
Catapult.spinFor(forward, 300,degrees);
Catapult.spinFor(reverse, 300,degrees);
if(Controller1.ButtonL1.pressing()){
Wings.spinFor(forward, 300,degrees);
if(Controller1.ButtonL2.pressing()){
Wings.spinFor(reverse,300,degrees);
if(Controller1.ButtonUp.pressing()){
Rollah.spin(forward);
else if(Controller1.ButtonDown.pressing()){
Rollah.spin(reverse);
if(Controller1.ButtonLeft.pressing()){
Rollah.stop();
(PID portion from @ TVA1814DeltaIII (Connor 1814D) on YouTube)
