Im having an error on the brain of my robot, and I am unsure what the issue is. I just updated the brain and the issue is now popping up.
Here is my code.
/* Module: main.cpp */
/* Author: VEX */
/* Created: Thu Sep 26 2019 */
/* Description: Competition Template */
// Robot Configuration:
// [Name] [Type] [Port(s)]
#define _USE_MATH_DEFINES
#include <cmath>
#include <math.h>
#include <algorithm>
#include <iostream>
#include "vex.h"
using namespace vex;
competition Competition;
controller Controller1 = controller(primary);
motor lF = motor(PORT11, ratio6_1, false);
motor lM = motor(PORT16, ratio6_1,true);
motor lB = motor(PORT17, ratio6_1, false);
motor rF = motor(PORT18, ratio6_1, true);
motor rM = motor(PORT19, ratio6_1,false);
motor rB = motor(PORT20, ratio6_1, true);
motor_group lefts = motor_group(lF,lB,lM);
motor_group rights = motor_group(rF,rB,rM);
drivetrain all = drivetrain(lefts,rights);
motor intake = motor(PORT16, ratio6_1 ,false);
motor uptake = motor(PORT2, ratio6_1,false);
motor_group Donut = motor_group(intake, uptake);
motor lift = motor(PORT1,ratio36_1,false);
encoder leftTrack = encoder(Brain.ThreeWirePort.A);
encoder rightTrack = encoder(Brain.ThreeWirePort.C);
digital_out pistonA = digital_out(Brain.ThreeWirePort.G);
digital_out pistonB = digital_out(Brain.ThreeWirePort.B);
/* Pre-Autonomous Functions */
/* You may want to perform some actions before the competition starts. */
/* Do them in the following function. You must return from this function */
/* or the autonomous and usercontrol tasks will not be started. This */
/* function is only called once after the V5 has been powered on and */
/* not every time that the robot is disabled. */
void pre_auton() {
vexcodeInit();
/* Autonomous Task */
/* This task is used to control your robot during the autonomous phase of */
/* a VEX Competition. */
/* You must modify the code to add your own robot specific commands here. */
void closer(void)
void far(void)
void skills(void)
void autonomous(void)
/* User Control Task */
/* This task is used to control your robot during the user control phase of */
void usercontrol(void) {
float speed;
float turns;
lift.setStopping(hold);
lift.setMaxTorque(200, percent);
bool a;
bool toggle = false;
while (1) {
turns = Controller1.Axis1.position();
speed = Controller1.Axis3.position();
a = Controller1.ButtonA.pressing();
//Drivetraain
lefts.setVelocity(2*(speed+ turns ), percent);
rights.setVelocity(2*(speed - turns ), percent);
lefts.spin(forward);
rights.spin(forward);
//lift
if(Controller1.ButtonR1.pressing() && !(Controller1.ButtonR2.pressing()))
Donut.spin(forward);
if(!(Controller1.ButtonR1.pressing()) && Controller1.ButtonR2.pressing())
Donut.spin(reverse);
if(!(Controller1.ButtonR1.pressing()) && !(Controller1.ButtonR2.pressing()))
Donut.stop();
if(Controller1.ButtonL1.pressing() && !(Controller1.ButtonL2.pressing()))
lift.spin(forward);
if(!(Controller1.ButtonL1.pressing()) && Controller1.ButtonL2.pressing())
lift.spin(reverse);
if(!(Controller1.ButtonL1.pressing()) && !(Controller1.ButtonL2.pressing()))
lift.stop();
if(Controller1.ButtonA.pressing())
toggle = true;
if(Controller1.ButtonB.pressing())
toggle = false;
pistonA = toggle;
pistonB = toggle;
// prevent wasted resources.
// Main will set up the competition functions and callbacks.
int main() {
// Set up callbacks for autonomous and driver control periods.
// Run the pre-autonomous function.
pre_auton();
// Prevent main from exiting with an infinite loop.
while (true) {
wait(100, msec);
