Mi microcontrolador se coloca blanco
estaba probando las orugas para mirar cuanta fuerza resiste este mecanismo. De un momento a otro el control en su pantalla se torna roja después en el control dice que el robot estaba perdido. Por consiguiente el cerebro se coloca blanco. Así que decidimos desconectarlo de su fuente de energía y dejarla descansar. Pasado el tiempo lo conectamos a su bateria donde queda igual al momento que se daño.
I went ahead and translated for ease of reading.
“I was testing the tracks to see how much force this mechanism resists. From one moment to another the control on his screen turns red after the control says that the robot was lost. Therefore the brain turns white. So we decided to disconnect it from its source of energy and let it rest. After time we connect it to its battery where it remains the same at the time it was damaged.”
It’s WSOD issues, if anyone didn’t catch that. Refer to the flowchart:
Is topic about broken motors?
Yes
ESD
No
Is topic about broken ports?
Yes
ESD
No
Is topic about why VCS won't work?
Yes
ESD that person’s hard drive ASAP. VCS was discontinued
No
Is the topic about some physical robot issue?
Yes
Dunno ask @technik3k
No
Is the topic in #website-forum-support ?
Yes
Just mute that channel, it’s always just spam advertisements
No
Is it a robot reveal?
Yes
Watch it, I guess
No
Is it a rules question?
Yes
The Q&A answer just made it 10 times more confusing
No
Is this topic a legitimate issue that requires response beyond the previous answers?
Yes
This topic is too high-IQ for the VEX Forum. Go to cheifdelphi.
No
Stop clicking buttons.
¿Por qué probaste eso? ¿La pantalla está rota en el controlador o en el cerebro del robot? VEX puede darle reemplazos si los contacta. Si la pantalla del controlador no funciona correctamente, entonces hay un botón en la parte posterior que puede restablecerlo, pero presiónelo con algo pequeño y largo, para que pueda alcanzarlo.
de lo contrario, si pudiera describir su problema más, sería genial.
well played at the end
Hola lozada, bienvenido al VEXforum!
¿Cuando desconectas y vuelves a conectar la batería, la pantalla continua a ser blanco, o funciona correctamente?
Si funciona correctamente, es un problema bastante común que se llama “pantalla blanca de muerte” (“white screen of death” en ingles). Aunque suene serio, no hay nada dañado permanentemente por este fenómeno. Solo es necesario desconectar y reconectar la batería.
Si la pantalla continua a ser blanco, debes contactar VEX por email en support@vexrobotics.com.
In English
Hi Lozada, welcome to the VEX Forum!
When you disconnect and reconnect the battery, is the screen still white, or does it work correctly?
If it works correctly, this is a fairly common problem known as the “white screen of death”. Although it might sound serious, nothing is permanently damaged. You only need to disconnect and reconnect the battery.
If the screen is still white, you should contact VEX by email at support@vexrobotics.com.
We fixed our white screen problem by changing the battery cable. Haven’t white screened since then.
esto podría deberse a que la señal de radio está bloqueada por metal en el bot, asegúrese de que la radio no esté rodeada por metal
wow. very impressive
Its likely an issue with static electricity. You need to have a way to dissipate that.
Middle school spanish did not adequetely prepare me to be making sentences though, so:
Tu roboto necesita disipar electricidad estática.
Lo siento si mi espanol es mal.
I hope that all means what I think it does.
Yep, you’re fine
I’m not too qualified to give advice tho, lol.
