Hi, My name is Patrick, I have just purchased a vex EDR starter kit (276-2700) to use with students. Below are my questions:
After pairing the microcontroller and the joystick, I plugged motors in port 2 and motor in port 5 (default code). Each motor spin continuously clockwise and cannot be controlled by the joystick.
The only port joined to a motor that can be controlled by the joystick is port 10 on channel 1. A motor plugged in any other port will spin continuously.
Can you let me know how to make sure that the robot moves/works according to the default configuration. Thanks.
Question 2:
What is the configuration to use the left stick (Channel 3) and the right stick (channel 2) to control the robot?
Thank you for your help
