Also, you should remove the 12-tooth gear and replace it with an 84-tooth gear, and have the 12-tooth gear on the same shaft as the 84 -tooth gear. If that doesn’t work, it’s either the angle or compression.
I am currently in middle school and I find this slightly offensive, although insulting may not be your intention. My first competition was back in October, and we competed in the High School division. We won Excellence and qualified for Nationals. I doubt their knowledge has anything to do with the fact that they are in middle school, a rookie high school student could easily make the same mistake.
Except slowing the 7:1, would be actually be a disadvantage because of the motor resistance.
No offense or insult intended. Rather my point is that the fundamental math skills relating to ratios are emerging at middle school level. Common Core standards introduce these skills in 6th grade and then continues in 7th grade. Moreover, there is the challenge of understanding that you are trading off speed for power in this case. High schoolers may be better handle on applying gear ratio concepts more consistently since they have learned these concepts and now putting them to practice.
My advice to teams continues to be is to look for primers on gear ratios when tackling flywheels. In this particular case, both motors driving gears should have the same size gears.
I do not doubt that there are middle schoolers who can explain gear ratios well. Our teams have some students who can, and some who can not.
The gear ration would actually be 24:1 as high speed motors increase the gearing by 1.6, not 2. Turbo increases your speed by 2.4.
Thanks for all your help. Especially Heavy Metal and Cyberbrains. The kids were able to get the ball to shoot lower goal this past weekend and spending more time with the above teams are still working on trying to get the launcher to go farther.
