Ran into an interesting bug in Modkit, and it took me a bit to track down exactly what was happening.
- I was using a “Drivetrain”
- Program was:
A) Turn LEFT 10 degrees
B) Turn LEFT
C) Wait 1
D) Stop
The robot would turn LEFT a bit, then turn RIGHT for 1 second.
The problem was caused by having the gear ratio set to 1:-1 (something I did when trying to reverse the motors, before I saw the checkboxes)
When I changed the gear ratio to 1:1, the robot would turn the same direction for both turns (as expected from the program)
Honestly, I’m not sure which direction it turns, only that with the gear ratio set 1:-1, the two “Turn Left” commands cause it to turn different directions.
Thanks
Steve
