Hello, we have recently started working with the V5 vision sensor and, although it has been working well, it disconnected momentarily from the brain today. In the event log on the brain, it simply shows that the camera disconnected at 00:35:11 and then reconnected again at 00:35:12. Is this anything that we should be concerned about? We are using a ready-made smart cable that came from Vex. Also, we are on a field with the new tiles that help prevent static. The robot was not moving fast or jerky at all when this happened. The last coding change made before this happened was a line added that referenced an inertial sensor which is also mounted on the robot. Is it possible that using these sensors together in some combination or sequence somehow might have caused the momentary disconnect? (just looking for some kind of explanation) Thanks!
Can you post the code?
