Motion Profiling
Hi, recently I implemented the motion profiling method for our autonomous, and I was just wondering how the robot would move when the generated path was from
{0_in, 0_in, 0_deg} to {3_in, 3_in, 0_deg}.
From my understanding, the x value moves the robot forward and backward, but what does the y value do with respect to the movement?
The y value moves the robot left to right. (Not up and down :laughing:)
But how would the robot move horizontally when the motors are powering the robot in a vertical direction?
The robot moves in an S-shape to reach the specified point, or can simply turn to face it, then drive to it (turning back at the end of the maneuver).
Then what’s the difference between the y value parameter and the deg parameter?
The degree parameter specifies the orentation of the robot at the end of the maneuver, with reference to the field.
If you were to remove previous profiles during autonomous and add new ones that were previously generated, do you need a new profile controller or can you do that with the same profile controller?
I’m not sure exactly what you’re asking, but I would say with the same profile controller.
I think he means if he can delete and make more paths with the same controller
EDIT: if that was ur question, the answer is yes
Yes;
Also, can I pre-generate paths during void initialize() ?
Yes you can, I would also recommend doing that as it conserves resources and saves time during the Auton Period
Would you recommend pre-generating them in initialize() or competition_initialize()?
Another thing, is the turning clockwise or counter-clockwise in default?
A) Personally just use initialize, not sure what competition initialize actually does or how it’s different
B) I’m fairly certain that they are clockwise but I don’t use Motion Profiling for turns so I could be wrong
When generating a new path based on the first path’s location, does the starting point have to be the coordinates for the first path?
Ex.
profileControllerA->generatePath({{0_in, 0_in, 0_deg}, {50_in, 0_in, 0_deg}}, "A");
profileControllerB->generatePath({{0_in, 0_in, 0_deg}, {0_in, 0_in, 45_deg}}, "B");
If I were to generate path B right after path A’s movement, would the starting point of path B have to be the end point of path A?
That’s not what I do, always reset that position to 0
So if I were to move a robot a certain distance forward then point turn the robot, would these path setups work?
profileController->generatePath({{0_in, 0_in, 0_deg}, {50_in, 0_in, 0_deg}}, "A");
profileController->generatePath({{50_in, 0_in, 0_deg}, {50_in, 0_in, 45_deg}}, "B");
I haven’t been able to successfully point-turn with profiling but ig it looks promising… lemme try this code on my bot later today and get back to u on that with say a vid.
okay, thanks for the support!
You cannot do a point turn using OkapiLib’s motion profiling (because pathfinder can’t generate negative wheel velocities).
