Motor and port not working
Hi everyone, I am having an issue with running a motor. I have the port that just burnt out with another one, and the motor is fine. The motor is not spinning to run the intake rollers. I have tried plugging it into another motor, and nothing is working.
Code
// VEX V5 C++ Project
#include <algorithm>
#include <cmath>
#include "vex.h"
using namespace vex;
competition Competition;
//#region config_globals
vex::motor      back_right_motor(vex::PORT1, vex::gearSetting::ratio18_1, true);
vex::motor      back_left_motor(vex::PORT10, vex::gearSetting::ratio18_1, false);
vex::motor      front_right_motor(vex::PORT11, vex::gearSetting::ratio18_1, true);
vex::motor      front_left_motor(vex::PORT20, vex::gearSetting::ratio18_1, false);
vex::motor      intake_arm_mover(vex::PORT5, vex::gearSetting::ratio36_1, false);
vex::motor      intake_left(vex::PORT12, vex::gearSetting::ratio36_1, false);
vex::motor      intake_right(vex::PORT19, vex::gearSetting::ratio36_1, false);
vex::motor      tray_mover(vex::PORT16, vex::gearSetting::ratio36_1, false);
vex::controller con(vex::controllerType::primary);
//#endregion config_globals
/*                          Pre-Autonomous Functions                         */
/*  You may want to perform some actions before the competition starts.      */
/*  Do them in the following function.  You must return from this function   */
/*  or the autonomous and usercontrol tasks will not be started.  This       */
/*  function is only called once after the V5 has been powered on and        */
/*  not every time that the robot is disabled.                               */
void pre_auton(void) {
  vexcodeInit();
/*                              Autonomous Task                              */
/*  This task is used to control your robot during the autonomous phase of   */
/*  a VEX Competition.                                                       */
/*  You must modify the code to add your own robot specific commands here.   */
void autonomous(void) {
//front_left_motor.spin(fwd);
back_left_motor.spin(fwd); //forward);
front_right_motor.spin(fwd);
back_right_motor.spin(fwd);
wait(2, seconds);
back_left_motor.spin(reverse);
front_right_motor.spin(reverse);
front_left_motor.spin(reverse);
back_right_motor.spin(reverse);
wait(1.25,seconds);
tray_mover.spin(fwd);
wait(0.75,seconds);
intake_left.spin(reverse);
intake_right.spin(reverse);
wait(1,seconds);
tray_mover.spin(reverse);
wait(2,seconds);
/*                              User Control Task                            */
/*  This task is used to control your robot during the user control phase of */
void usercontrol(void) {
  while (1) {
     //Setting the speed of the intake rollers and the arms holding the intake rollers
    while(true) {
      int intakeleftSpeedPCT = 100;
    int intakerightSpeedPCT = 100;
    int intakearmSpeedPCT = 75;
    int traymoverSpeedPCT = 25;
        if(con.ButtonL1.pressing()) {
                intake_left.spin(directionType::fwd, intakeleftSpeedPCT, velocityUnits::pct);
            else if (con.ButtonL2.pressing()) {
                intake_left.spin(directionType::rev,intakeleftSpeedPCT, velocityUnits::pct);
            else {
                intake_left.stop(brakeType::brake);
                intake_right.spin(directionType::rev, intakerightSpeedPCT, velocityUnits::pct);
                intake_right.spin(directionType::fwd,intakerightSpeedPCT, velocityUnits::pct);
            else {
                intake_right.stop(brakeType::brake);
                if(con.ButtonUp.pressing()) {
                intake_arm_mover.spin(directionType::fwd, intakearmSpeedPCT, velocityUnits::pct);
            else if (con.ButtonDown.pressing()) {
                intake_arm_mover.spin(directionType::rev,intakearmSpeedPCT, velocityUnits::pct);
            else {
                intake_arm_mover.stop(brakeType::brake);
                     if(con.ButtonLeft.pressing()) {
                tray_mover.spin(directionType::fwd, traymoverSpeedPCT, velocityUnits::pct);
            else if (con.ButtonRight.pressing()) {
                tray_mover.spin(directionType::rev,traymoverSpeedPCT, velocityUnits::pct);
            else {
                tray_mover.stop(brakeType::brake);
        //Get the raw sums of the X and Y joystick axes
        double front_left  = (double)(con.Axis3.position(pct) + con.Axis4.position(pct));
        double back_left   = (double)(con.Axis3.position(pct) - con.Axis4.position(pct));
        double front_right = (double)(con.Axis3.position(pct) - con.Axis4.position(pct));
        double back_right  = (double)(con.Axis3.position(pct) + con.Axis4.position(pct));
        //Find the largest possible sum of X and Y
        double max_raw_sum = (double)(abs(con.Axis3.position(pct)) + abs(con.Axis4.position(pct)));
        //Find the largest joystick value
        double max_XYstick_value = (double)(std::max(abs(con.Axis3.position(pct)),abs(con.Axis4.position(pct))));
        //The largest sum will be scaled down to the largest joystick value, and the others will be
        //scaled by the same amount to preserve directionality
        if (max_raw_sum != 0) {
            front_left  = front_left / max_raw_sum * max_XYstick_value;
            back_left   = back_left / max_raw_sum * max_XYstick_value;
            front_right = front_right / max_raw_sum * max_XYstick_value;
            back_right  = back_right / max_raw_sum * max_XYstick_value;
        //Now to consider rotation
        //Naively add the rotational axis
        front_left  = front_left  + con.Axis1.position(pct);
        back_left   = back_left   + con.Axis1.position(pct);
        front_right = front_right - con.Axis1.position(pct);
        back_right  = back_right  - con.Axis1.position(pct);
        //What is the largest sum, or is 100 larger?
        max_raw_sum = std::max(std::abs(front_left),std::max(std::abs(back_left),std::max(std::abs(front_right),std::max(std::abs(back_right),100.0))));
        //Scale everything down by the factor that makes the largest only 100, if it was over
        front_left  = front_left  / max_raw_sum * 100.0;
        back_left   = back_left   / max_raw_sum * 100.0;
        front_right = front_right / max_raw_sum * 100.0;
        back_right  = back_right  / max_raw_sum * 100.0;
        //Write the manipulated values out to the motors
         front_left_motor.spin(fwd,front_left, velocityUnits::pct);
          back_left_motor.spin(fwd,back_left,  velocityUnits::pct);
        front_right_motor.spin(fwd,front_right,velocityUnits::pct);
         back_right_motor.spin(fwd,back_right, velocityUnits::pct);
    // This is the main execution loop for the user control program.
    // Each time through the loop your program should update motor + servo
    // values based on feedback from the joysticks.
    // Insert user code here. This is where you use the joystick values to
    // update your motors, etc.
                    // prevent wasted resources.
// Main will set up the competition functions and callbacks.
int main() {
  // Run the pre-autonomous function.
  pre_auton();
  // Set up callbacks for autonomous and driver control periods.
  //autonomous();
  // Prevent main from exiting with an infinite loop.
  while (true) {
    wait(100, msec);
Ok, so it turns out the brain is not programming. Does anyone know what is happening?
Can you explain more ? What IDE are you using ? Ok, VEXcode, I should have looked at your code.
What do you mean “brain is not programming”?
Can you download the program?
Is USB port bad?
Can you run the program?
Are there multiple programs on the brain?
Are you running the latest one?
I hope you get it working for the competition.
And I wanted to give you a big :heart: for putting your code into code tags and into dropdown. It looks really neat and sets a great example for everyone.
Haha, I added the code tags, it was in the dropdown though. I often fix code that is posted without tags.
