Motor Controller placement
I did a bunch of searching but couldn’t find an answer, even though I believe I have seen the answer before.
Which is better and why:
  1. Motor controllers directly plugged into the cortex or the power expander, and then use a 2 wire extension if needed for the motors, or
  2. 3 wire extensions from the cortex/power expander to the motor controllers and plug the motors directly into the motor controllers
Or doesn’t it matter?
I seem to remember that the controllers should be closer to the cortex, but I’m not sure. Does it help cut down on noise with the PWM signal?
There’s a note on the motor controller product page recommending no more than one 3-wire extension cable, and use 2-wire extensions after the controller if more length is needed. https://www.vexrobotics.com/276-2193.html
