Motor Idle Question
is there a way to turn off the idle in the motors cause the servo has a potentiometer but the motors dont so …
Help ??
its shouldnt be too hard i think
i can solder somethin inside if needed
What!!!
What Idle?
no the motor moves a little when im not doin anything like at top speed it uses 7.## volts but at idle when both the radio and the microcontroller are on you can hear it hum and move a tiny bit or is my vex thing wacked and can i fix it?
It sounds like your trim settings are off on the UI, try adjusting them.
mine does the same thing but when i go to adjust the trim it gets worse but it only does it when i program the microcontroller but not when i put the master code on the microcontroller
