Motor Reversing in VexCode
I have tried to reverse the motor in the setup, to no avail. The motors are still not reversed, but if i call M.spin(directionType::rev, whateverpower, percent) for example, it will spin reversed. I have swapped V5 Brains out, and same result. This also Happened in VexCoding Studio.
Try this code when you initialize the motor.
vex::motor name (vex::PORT1,true);
The true says that reversed is true so the motor will be reversed whenever you use the motor.
OOOOH Thank you so much! I’m an idiot! I said false because i thought that meant reversed XD
