Hello there viewer.
I am coding the functions for my tray lift and my claw and I am trying to find motor speed values that go (about) the same speed as other values that are moving the other direction. Here is an example of my code.
if(vexRT[Btn6D] == 1)
motor[port1] = -63.5;
else if(vexRT[Btn6U] == 1)
motor[port1] = 63.5;
else
motor[port1] = 0;
The problem I am trying to find out is to get the Btn6D motor value to be the same speed as the Btn6U motor value but in the negative factor.
I also wonder if there’s just something generally wrong, because at -63.5 speed, the claw jolts to grab whatever is in it’s way. (Most cases air.)
(Sorry if my formatting on this topic is confusing.)
I’ll try every given value out or just test certain theories. Thank you.
