I’ve got problem with one of my VEX IQ Motors, it doesn’t want to stop. For example when I’m driving forward and realeasing the joystick motor slows down, but still rotating. I don’t think its a joystick problem, tried it on differen ports. Do You have any idea what might be the problem
Firstly I would try calibrating your controller. The Knowledge Base article that explains this is here:
If you have one of the older style IQ controllers (usually just have a VEX logo on the front, not a VEX IQ logo), make sure the joystick is push down (as in actually push down into the controller) properly. Sometimes the old ones can pop up a bit and cause some friction which stops it from returning to the centre properly.
Unfortunately, That didn’t help. It doesn’t matter if I use a joystick or a code to control robot. if I use motor, it doesn’t stop rotating, it just slows down.
Can you create a new VEXcode IQ project. Only add 1 device, just the motor that you are referring to. Don’t add a controller or any other devices.
Create a simple program like this and see if the motor stops:
And to learn more about how to implement a deadband, you can check the example programs in VEXcode IQ. Go to File, Open Examples, choose Motion and then use the Arcade Control or Tank Control examples.
