If you want to convert from 6.5 inch/lbs to oz/in, you have to convert 6.5 inches to oz and lbs to inches. Are you sure you want to convert to inches/oz not oz/inch?
the scale from from lbs to oz would be 1lb/16 oz. This would not work if you wanted to convert to oz/inch.
Guys… it’s not oz/in or in/oz, it’s ounce*in. They’re multiplied together. It’s “ounce-inches” not “ounces per inch”. It would be 104. Anybody tried it? I guess I could give it a go, I’ve got extra parts for whatever innards that strip.
In the following link, I have the data for one of my motors: https://vexforum.com/t/how-to-find-max-power-curve-of-motors/12697/1
That thread has a previous post where I describe how to measure it.
Basicly, wrap a string around a wheel and use it to lift a weight;
the torque is the weight * radius of wheel.
My motor was quite a bit underpowered from the spec.
I didn’t have any problem with stripping internal gears when the motor stalled
this way.
