Motor troubleshooting
Hello, I was working on this motor and it stopped moving with the following code:
void autonomous() {
    Motor Prueba (19);
    Prueba.set_brake_mode(E_MOTOR_BRAKE_BRAKE);
    Prueba.move_voltage(12000);
    delay(3000);
    Prueba.move_voltage(6000);
    delay(3000);
    Prueba.brake();
Tried:
  1. modifying code
  2. changing cables
Could anyone help?
Iā€™m not a coder, but Prueba.brake() sounds like something that would stop the motors. Pro forumers might be able to help you better
Is the red smartport led illuminated on the motor ? If so, check the motor works using the dashboard, if not the motor is probably dead.
