It would probably work, as long as you only used commands for one or the other at a time.
An alternative may be to create a new sub class and add the functionality you want, more complicated but may have better long term capability. something along these lines perhaps.
smartdrive for x drive class
class smartdrive_x : public smartdrive {
private:
vex::motor &m_lf;
vex::motor &m_lb;
vex::motor &m_rf;
vex::motor &m_rb;
vex::motor_group m_l;
vex::motor_group m_r;
motor_group &set_lm( motor &m1, motor &m2 ) {
return (m_l = motor_group(m1, m2));
motor_group &set_rm( motor &m1, motor &m2 ) {
return (m_r = motor_group(m1, m2));
public:
// adjust defaults as necessary
smartdrive_x( motor &m_lf, motor &m_lb, motor &m_rf, motor &m_rb, vex::guido &g, double wheelTravel=200, double trackWidth=150, double wheelBase=150, distanceUnits unit=distanceUnits::mm, double externalGearRatio = 1.0 )
: smartdrive( set_lm(m_lf, m_lb), set_rm(m_rf, m_rb), g, wheelTravel, trackWidth, wheelBase, unit, externalGearRatio),
m_lf(m_lf),
m_lb(m_lb),
m_rf(m_rf),
m_rb(m_rb) {
~smartdrive_x(){}
void xdrive( int fwd_back, int turn, int right_left ) {
// Set drive
int drive_l_front = fwd_back + turn + right_left;
int drive_l_back = fwd_back + turn - right_left;
int drive_r_front = fwd_back - turn - right_left;
int drive_r_back = fwd_back - turn + right_left;
// normalize drive so max is 100 if any drive is over 100
int max = abs(drive_l_front);
if (abs(drive_l_back) > max)
max = abs(drive_l_back);
if (abs(drive_r_back) > max)
max = abs(drive_r_back);
if (abs(drive_r_front) > max)
max = abs(drive_r_front);
if (max>100) {
drive_l_front = 100 * drive_l_front / max;
drive_l_back = 100 * drive_l_back / max;
drive_r_back = 100 * drive_r_back / max;
drive_r_front = 100 * drive_r_front / max;
m_lf.spin( forward, drive_l_front, percent );
m_lb.spin( forward, drive_l_back , percent );
m_rf.spin( forward, drive_r_front, percent );
m_rb.spin( forward, drive_r_back , percent );
void strafe( int right_left ) {
xdrive(0, 0, right_left);
initialization of the motor groups is a little messy as you have to create them before the base class constructor is called. Motors are saved in some private variables to be used as desired.
you would use it like this. (this is EXP code, change the inertial sensor for V5)
// motors for mecanum drive
motor mlf(PORT1);
motor mlb(PORT2);
motor mrf(PORT4, true);
motor mrb(PORT5, true);
// internal imu on EXP
inertial imu1;
controller Controller(primary);
smartdrive_x sd( mlf, mlb, mrf, mrb, imu1 );
int main() {
sd.turnToHeading( 90, degrees );
Brain.Screen.printAt(10, 10, "done");
while(1) {
int fwd_back = Controller.Axis3.position();
int turn = Controller.Axis4.position();
int right_left = Controller.Axis1.position();
sd.xdrive( fwd_back, turn, right_left );
// Allow other tasks to run
this_thread::sleep_for(20);
that doesn’t give you any “strafeFor” distance or anything, but you could add those functions to the class as needed. The smartdrive turnFor etc. will work as usual.
